Question about Refrigerators
Melted plastic floor in Freezer
I've got an old refrigerator/freezer. I noticed in the freezer there is a hole in the plastic floor. It looks like it has melted. The refrigerator was given to us used and originally I just thought it had happend a long time ago and wasn't a real issue, the unit seems to be working fine.
Well I noticed yesterday I could see what seems to be exposed heating elements inside the hole, and my wife has reported that some hotdogs we had in the freezer where burned. I am thinking this can't be good.
Am I risking a fire if I continue to use it? Anyone ever see something like this before, what could be causing this?
I guess I need someone just to tell me to unplug the thing and throw it away and get a new one, or is there an easy fix? This is our back up refrigerator in our garage and is not worth putting any money into.
Thanks
  • patrick_sore Oct 07, 2009
    I checked it last night and it is a Magic chef. And I think you hit the nail on the head on with the issue. Is there a way just to disable the freezer/Defrost function? Would just turning the dial on the freezer portion down shut it off or would the defrost feature still kick on?
    I would then just plan on using as a back up refrig for drinks, which is pretty much its function right now. Just looking to buy some time before I replace it.
    Thanks for the help
  • patrick_sore Oct 08, 2009
    Model number is RB17KN1AF.
    Thanks for all your help on this.
  • Refrigerators Master
  • 1,606 Answers
The refrig is possibly a Magic Chef . This refrig has the coils AND defrost heater , under the freezer floor . If the defrost thermostat sticks , the heater will eventually burn thru the aluminum coil cover and melt the freezer floor . However , with the freezer floor burnt thru , the freezer fan is not pulling the complete air flow , over the coils , which in turn , a lot more electricity is being used , to try to keep the complete refrig cool . To repair , you would need 1 ) defrost thermostat , 2 ) freezer floor , 3 ) foil coil and heater cover , 4 ) a few hours or days ( if not done before ) .
So , no , not an easy fix .
Posted on Oct 07, 2009
  • Mike Smith
    Mike Smith Oct 07, 2009
    If I had the model number , I could tell you where the defrost timer is , and you could clip one of the 2 motor wires . This would stop the defrost function .
  • 41 Answers
Get a new refrigerator,. You have a fire hazard. The compressor motor is probably overheating.
Posted on Oct 06, 2009
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
My GE refrigerator Model TBX18SA is draining condenste water at the bottom and also inside.How to get rid of it ?Thanks.
That happened to us on our freezer side by side. Pull out whatever is in the bottom of your freezer, a shelf or a basket. Look on the floor of the freezer toward the back. You should see a small dime or nickle sized hole that may be covered in ice. It should have a cover on it with small holes. Check that nothing is blocking that hole. Something has probably fallen on top of it and has blocked its ability to drain thru the hole into the drain pan under the fridge when the defrost cycle comes on and the melted ice can't drain down properly. We used a hair dryer on low to carefully melt the ice that had formed on the bottom to find the drain. Sure enough a small piece of plastic wrap was blocking it. We removed the plastic and continued with the hair dryer til we could pour water in the hole and it flowed freely to the drain pan and didn't continue to back up into the freezer floor.. Be very careful with the hair dryer, put it on lowest setting and keep it moving back and forth, don't hold in one place, or it could melt or warp the plastic sides of the fridge. When the hair dryer is on low, put your hand about a foot in front of it and it should feel warm not hot. Move your hand forward til you feel the air is just warm, this is the distance you want to keep it from the ice you are melting. As the ice melts use a small towel to mop up the melted ice as you go. Good luck
Aug 03, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Water is filling up on the bottom of the freezer floor...freezes and then partially melts, dripping out onto the floor.
It's to do with the defrost cycle. The appliance will autmatically go into this and normally you would not notice. What has happened is the hole that the defrosted water disapears through is blocked and the water is freezing in ur appliance rather than running away. Have a look at the back of the appliance inside the freezer and look for the hole then pour a little hot water down it to release the block.Sometimes the hole can be hidden behind a panel with small grills on it.
Hope this helps
Mar 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Freezer is leeking water into the bottom of it ,
I had the same problem.
This is how I solved it.
Remove the bottom drawer of the freezer. There was a lot of ice built up.
I chiseled it out, and then looked in the back.
There is a drain hole that was blocked by a fallen popsicle that melted, and then the plastic wrapper plugged the hole.
Check that the hole is not blocked.
Also, it is always a good idea to remove the bottom black vent cover under the fridge and clean out any dust build up with a vacuum.
Good luck.
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Apr 22, 2009 | Frigidaire PHSC39EGS Side by Side...
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Water drains internally at back of freezer drawer
Check the drain.
Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
Dec 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Refrigerators Logo
412 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
