Question about Panasonic PV-C1343 13 in. TV/VCR Combo
TV will not work with remote. Took out batteries
TV will not work with remote. Took out batteries and pressed each button and then replaced the batteries. Still nothing.
  • 647 Answers
Try a universal remote to confirm if the problem is the TV or remote - 99% of remote problems are related to the remote not the TV. It's probably worth buying a universal remote (Walmart electronic store) to program and try.
If this helped Vote/Rate me Thanks
Posted on Oct 05, 2009
Testimonial: "Thank you for your help. I have ordered a remote and will see if it helps. thanks again..."
My TV volume will turn up but not down via remote and TV buttons. I took the batteries out of my remote and no change, so I dont think it is a remote issue. I tried to reset the audio, standard settings,...
The buttons on most remotes are the soft rubber type. The conductive film under the rubber is very thin and gets damaged very easily when pressed really hard. If you can still change the volume using the buttons on the TV and one or more buttons on the remote works and not works at times then it a bad button on the remote. Unfortunately you can't just change a single button as it's mounted on a pad. The whole remote needs changing. Check with TV vendor or look for a replacement on Amazon.com. Try to get the exact model and avoid using a universal remote. Yes, they work for basic functions but won't have the specials lik PIP (picture in picture).
* Oh, if your using a cable box. You may be able to program the cable remote for use with your TV (at least to control power and volume) Check you cable channel for setting up the remote. (They usually have a dedicated instruction channel.)
Aloha, ukeboy57
May 29, 2018 | Televison & Video
Mine just stopped working. Can it be reset?
Take the battery out from it compartment. The remote control will reset itself after some time. The re-insert the batteries, and check the remote control for its infra-re emission.
Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 24, 2014 | Monster Cable MCC AVL300-S Remote Control
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    NOTES:
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Need remote codes for Ilo TV.
Hi!
Turn on TV and press the TV button by aiming it to TV, the red LED light will blink once. Press the MUTE/SEARCH button. The LED will shut off first then light up. When the TV turns off, press the OK button to store this code.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Televison & Video
Remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Feb 18, 2009 | Samsung TV Remote Control
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic PV-C1343 13 in. TV/VCR Combo Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
