Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400
Hi: My usb ports on this machine are not working properly. When i plug a memory stick or a camera in it says that the device is not working properly. But these devices all work on other machines. I've been told to uninstall all the drivers in the device manager and then reinstall them but i'm not sure how to do this with the key-board. When i uninstall these usb ports will i not loose the use of my Mouse? How do i shut the computer down and reboot without a mouse?
HELP!!!
  • 1 more comment
  • jackjoan Jan 25, 2008
    I put a flash drive into all of my usb ports and none of them are working. What should we do?
  • Anonymous Dec 08, 2008
    i have the exact problem with the previous individual(s) with the same machine(Dell dimension 2400). It obviously appears to me that Dell has a known issue that particular PC and would'nt assist in resolving it without a high cost/charge.
  • w3a51l Mar 20, 2009
    My sisters Dimension 2400 has a similar problem. USB mouse works fine, but 2 different known good USB keyboards will not work. Have moved the USB connectors and the problem remains with the keyboard. PS2 keyboard works fine though. Any ideas on how to get the USB keyboard going again?
Do i have to install a new driver for it to work properly? because every time i plug in memory sticks, flash drives with 1gig and higher capacity, i won't work... please help me, what will i do.
Posted on Jul 22, 2008
  • 43 Answers
You may want to temporarily connect a PS2 mouse (and keyboard if you wish)
The PS2 connectors are round, a purple one for the keyboard and green for the mouse.
If you have the original Dell disks that came with the system, one will be a driver disk (don't accidentally re-install windows from the other disk).
most drivers are available at:
http://drivers.myfreewares.com
Posted on Oct 25, 2008
    Sergeant:
    Champion:
  • 270 Answers
A computer proffesion dosent need a mouse to wok on computer . the windows (logo) botton opens the strt menu . then scroll it with up and down arrows press enter to select . tab to switch between windows and drives . windows key+ e opens my computer . windows +d reduces windows
Posted on Dec 23, 2007
My dell dimension 4600 is not recognizing my ipod shuffle
Does it recognize any other usb device you stick in the port?
Try a different USB Port, maybe the one you are using is bad.
Do you get a message saying your device will run faster if it was connected to a 2.0 USB device?
If so you could try updating to a 2.0 usb device which goes into one of the PCI slots inside the computer for less than $15.
Click the link below to purchase a 2.0 PCI USB adapter. when the site opens just type: PCI to USB Adapter in the white search box at the top of the webpage and hit GO. Sort the results by Prices Low to High.
http://www.tigerdirect.com
I use the one in the link below for computer repairs. It costs $9.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265856&CatId=511
Apr 25, 2012 | Dell Dimension 2400 PC Desktop
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
No audio from external speakers dell 2400 computer
hi,
1)Check audio Enabled in bios
2)Check whether audio drivers are installed in device manager if not install audio driver for DIMENSION 2400 from Support.dell.com
3)Check Audio port using Head phones to ensure is audio port is working fine.
4)If Dell speakers, check speakers Manuals from support.dell.com
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Went to a convention we were supplied with a memory stick of part of the proceedings..have Dell Dimension2400 windows xp sp 3 ,have no idea how to use it please advise
Just plug the flash drive into one of your USB ports and on the lower right hand corner of your screen you should see a balloon that says "USB mass storage device detected." Click on that balloon and it will open the file up.
Nov 01, 2009 | Dell Dimension 2400 PC Desktop
USB ports and resolution failures
Reinstall your drivers you'll find them in your control panel
Apr 11, 2009 | Dell Dimension 2400 PC Desktop
Usb issues
Go into Device Manager, then right-click on the problem hardware, and select
properties. From there, you can get computer to look on the Internet for updated
drivers, to upgrade from USB 1.0 to 2.0.
Mar 10, 2009 | Dell Dimension 2400 PC Desktop
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Dell 4600 usb ports not working
Have you gone to Start>Control Panel>Device Manager to see if there are any yellow exclamation marks in front of the usb devices?
Oct 25, 2008 | Dell Dimension 4600 PC Desktop
USB
Its more likely that there could be a loose connection to the motherboard. If not try to attach some ports to the same place on the motherboard and if they also dont work motherboard at fault if they do obviously your old ports are dead for some reason. Good luck.
Oct 01, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
924 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
