Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire washing machine no spin cycle
The washing machine stops after the wash cycle and never goes to rince or spin.
  • Anonymous Mar 25, 2014
    Do washing machines go through the spin cycle on delicate?
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean.(Refer manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 11, 2008
I have the exact same problem - 2006 machine - where can I buy a control board?
Posted on Dec 02, 2009
Washing machine stops on rince cycle
when the unit sense a strong vibration it automatically stop the unit. unplug the unit and wait for thirty seconds then open the lid and redistribute the cloths inside to balance the load then close lid then plug unit then push power and program your washing again
Feb 24, 2016 | Electrolux Ewf1090 Front Loader Belt Part...
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Frigidaire washer wont go into spin cycle
    Check the lid switch for proper operation.
    Jun 17, 2008 | Frigidaire Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Frigidaire GLTR1670A Front Load Washer Logo
    1,581 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
