Question about Kenmore Refrigerators
My refrigerator isnt as cold as it should be. The freezer works perfect but refrigerator isnt staying as cold.
    President:
  • 1,304 Answers
Check your freezer fan, is it working, you may need to hold the door switch in if there is one,
next check your freezer carefuly for frost
then try to see if you can feel air in the refer with the freezer door closed...
Posted on Oct 06, 2009
Our sharp fridge/freezer model SJ-45F-WH ISNT GETTING COLD IN THE FRIDGE. THE FREEZER IS WORKING PERFECTLY.WE HAVE TURNED IT OFF FOR A FEW HOURS AND TURNED IT ON AGAIN. THAT WORKED LAST TIME.Not now.
If your freezer is full of food move everything about an inch away from the back wall. This should let the air flow better the fridge gets its cold air from the freezer. So you have to make sure your not blocking the vents.
Nov 03, 2016 | Sharp Refrigerators
My gold star three door gr403s fridge isnt staying cold in the fridge section only. the freezer is fine but the middle chiller section is also having a few issues. Im not able to replace is as Im a pe
You might check this link for details that are similar to your fridge issue. Likely you do not have cold air fanning to the bottom compartment hence not cool. I assume your seals work properly and that it is a fridge internal issue.
Refrigerator Repair Not cooling properly freezing up on the back panel...
Feb 13, 2015 | Refrigerators
My subzero refrigerator section will not stay cold. The freezer is working perfectly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Sub-Zero Refrigerators
It isnt staying cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 18, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
