Not getting all channels on brandnew flatscreen TV LG 42PQ1000.
Not getting all channels on LG 42PQ1000. Shop has replaced first unit and antena company say I'm receiving too much signal from roof-top aerial and will need an in-door attatchment to reduce incoming signal. Is this true? The aerial was adapted a year or so ago to pick up DTV reception.My previous flatscreen worked and still does work perfectly. Nothing has been changed in terms of plugs or cables.
  • 2,192 Answers
Yes the incoming signal can overload the tuner
Posted on Aug 01, 2017
5 Suggested Answers
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: Can't tune in my Samsung DTV channels
WDDW
Posted on Nov 17, 2008
  • 325 Answers
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
tekkiinh
  • 59 Answers
SOURCE: Tvs get reception from an
The tuner on the LG TV may be right on "the hairy edge" of being able to receive that signal. Therefore the processor won't acknowledge and display it. You may want to try the LG on one of the other antenna feeds were the TVs DO display that channel. You might want to try the LG with no other sets hooked up. You may have a problem with any of the following. - staple through a wire - cracked lead-in wire or damaged coax - problem with a distribution amp/splitter.
Posted on Oct 01, 2011
How do i get channels on my lg lcd tv?
Grab your remote click menu scroll to tv tuner select auto tune ? Make sure your antena is pluged in the back of you tv
Mar 18, 2012 | LG Televison & Video
Tvs get reception from an antena. New LG tv won't acknowledge a dtv channel (kxtv sacramento) when scanned or manually added. Two other digital tvs utilizing the same antena scanned and added the...
Sep 12, 2011 | LG 42 42PT350 42 Plasma TV
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
May 09, 2011 | LG 42LH40 LCD TV
How do i get freeview reception on my 19' LG TV/MONITER its not picking up any channels in bedroom...recommend best antenna to fix please
Get a Digital antena,any name brands.Make sure it put some where high,will get all the free air tv channels.
Apr 12, 2010 | LG M1910A 19 in. LCD Television
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
Bbc channels are ok but other channels are sticking and the picture is braking up during transmission what can i do ??
This pay tv rescan channels.Free over the air tv get a better antena like a digital antena or roof antena.
Oct 31, 2009 | Digi Televison & Video
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Oct 17, 2009 | Televison & Video
I can not get some local channels but my converter box picks them up on other TV"s with no problems from the same out side antena. Why?TV is a LG super slim XD DTV
the only converter box in my house is in the bedroom. I have to scan each night for Channel 11 and in the morning its a black screen. Is it the box or Channel 11?
Jul 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical line on new TV, for some channel
It seemed an antena problem. Previously I did not connect with antena with a proper cable. Now
with a new cable, the problem has been sorted out. Thank you.
Jun 11, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
