Question about HP Pavilion dv6000z Notebook
Hp zd9500 My I.T. put in a new hard drive the other day and it was running fine. Today I turned it on, it was booting up and then went completely dead - no lights, or anything. The power cord is working - I removed the battery & tried the power cord - nothing happens - it is completely dead.
    Sergeant:
    Novelist:
  • 191 Answers
You could test to see if hard drive is culprit by removing the drive. This is done by removing the access panel on bottom of laptop and slipping out the drive. Once out, try turning on laptop. It won't boot up, but you should get power light on.
I suspect you will not.
If so, problem is in power supply within laptop. Fixing requires a full diagnostic check of the power supply and battery charger. I highly recommend a trained technician for that.
Posted on Oct 05, 2009
My hp dv5215us laptop monitor broke several months ago. I've been using the computer with an external monitor plugged in to the vga port, but I turned it on today and the external monitor isn't...
Hardware failure of the motherboard - most likely something went wrong with the northbridge.
The repair will cost way more than it's worth, this laptop is effectively dead, time for a new one
Jul 20, 2011 | HP Pavilion dv5215us Notebook
Three days ago my son spilled water near my computer. A little bit went on keyboard. The computer then would not trn on. Earlier today the computer turned on and went to fix screen but it kept loading...
Fist clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU if the fan is not working your PSU is faulty
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty
then you might try
during the boot up process for a short time you will see press a certain key to enter set up
press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
hope this helps
Dec 11, 2010 | Computers & Internet
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
My presario want boot
if you still have an installation disk, put it in, restart, and run a startup repair. if that doesn't work, try to do a system restore. if that doesn't do anything you'll have to completely re-install windows.
Apr 16, 2010 | HP Compaq Presario C700T
I've put a new Western Digital Hard Drive in Today But it wont boot up,
if it is an external drive go to Bios and turn the usb emulation to no boot
if it is an internal drive check if is detected
Nov 05, 2009 | Western Digital My Book Essential Edition...
I have a Gateway M675 laptop. It was stolen on Mothers Day 2009. I received my laptop back into my hands 2 days ago, long story as so how I got it back. I tird to powerup my laptop, but it would open with...
you will have to check online for your BIOS setup it is trying to boot from something that is not there have to set BIOS from UEFI to normal.
Or
Install windows using thumb drive and win32disk to install windows to thumb drive then boot from thumb drive by pressing F12 or F11 for boot order
Feb 28, 2017 | Gateway M675 Notebook
Hp c762nr will not boot and blacklight will not come on when on
open the back case of Hard and Memory..remove the hard drive then remove the memory...after u remove the memory try to clean the memory using a paper eraser then put it back the memory.about hard drive/Hard Disk do not put it back only memory to test and run the unit.if unit is back to power on self test try put it back the hard drive/HDD then try boot all system.if their is message hard fails i think u need to try to replace the Hard Disk...Thanks and Good Luck...GOOD DAY...
May 29, 2009 | HP Compaq Presario C762NR Notebook
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Hard drive controller
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Jul 30, 2007 | Compaq Armada 1700 Notebook
HP Pavilion dv6000z Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
