Does the HP P6109 Pavilion have a built in modem?
  • 2,841 Answers
It has an Ethernet port where you can connect a modem. It may or may not have a dial-up modem built in. If you see a standard phone connection it has a dial-up modem built in.
Posted on Oct 05, 2009
    Sergeant:
    Novelist:
  • 191 Answers
Built in or expansion card, there should be a place to plug in the phone line on backside of computer. If you do not see one, you do not have a modem installed.
Bret
1-2-1ComputerServices
Screen frame broke
Screen frame being the Display Bezel.
http://h10032.www1.hp.com/ctg/Manual/c01573159.pdf
With the laptop closed, the top cover is the Display Enclosure.
Is it broken also?
http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/Detail
Can you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.
The HP part number, for the Display Bezel of the HP G70 series, is;
HP 488386-001
The HP part number for the Display Enclosure is;
HP 488379-001
Base Enclosure;
With built-in modem, Digital Media slot, AND -> with HDMI port,
HP 489114-001,
http://www.impactcomputers.com/489114-001.html
Base Enclosure:
WITH built-in modem, Digital Media slot, and NO -> HDMI port,
HP 501252-001,
http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8
Hinge Kit; (2 each Hinges),
HP 488384-001,
http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001
You have more damage than just the Display Bezel, I feel.
Access what damage you have, and I'll step by step guide you in replacing.
Just post back in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | HP G70-250us Notebook
I want to know if I can connect the modem board out of my all-in-one HP G85xi to the motherboard in my hp pavilion? I don't want to crash my computer.
No! the configuration settup is different, not to mention the lay out. The modem must replaced with the original specifications that are called for.
Apr 22, 2012 | Computers & Internet
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
Can' see network adapter on hp a375c
is the modem built into motherboard,if not,need one fitted,
Jul 03, 2010 | HP Pavilion a375c (A375CBEC6719) PC...
HP pavilion desktop only has built in RJ45 connector--problem?
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
This is a very large subject so you need to decide what you want to do first!
See
http://www.computerhope.com/issues/ch000469.htm#04
or
http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
or even
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Sep 12, 2009 | HP Pavilion Media Center TV Desktop with...
HP pavilion dv5-1125nr notebook, dial up modem is not working
Save yourself alot of grief. Purchase a PCMIA or USB modem and your done. A very inexpensive fix. I am a certified HP Master tech and I will tell you that HP does have some consistent problems withg their modems. If you can spare a few bucks go to www.driveragent.com and try to locate an updated driver.
Jul 30, 2009 | HP Pavilion dv5-1125nr Notebook
DRIVER MODEM 3732 USED WIN XPRO DOESN'TWORK
with the brand(hp/compaq) and model of your computer you can find the drivers from www.hp.com
May 20, 2009 | Computers & Internet
I am not finding modem driver .. ihave to use dial up on my laptop dv2500 hp pavilion.. kindly help as it gives data interface error when i try to connct
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3369421&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
you can downoad the driver from above link. But first check if there is no modem any other modem driver installed which might conflicting with your active modem and query the modem. The instructions are
go to control panel click on phones and modems. a window will open up. click on the modems tab . check whichever modem showing not present select it and remove it. then close it. delete the dialup connection and recreate it. it should work.
Mar 22, 2009 | HP Pavilion dv2500t Notebook
I need modem pci and compatible vga hp pavilion ze4500
can I use a 2 wire Router with a SB5101 modem?
Nov 18, 2008 | Computers & Internet
Need pci modem driver for pavilion laptop model #F4903H
http://www.hp.com/#Support
hp has a great drive download area. just search for you model number; pick your OS; download drivers for the modem; then install them
Nov 14, 2008 | HP Pavilion ze4115 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
