Question about HP PSC 2410 All-In-One InkJet Printer
How do I check to see if I need new cartridges for my printer?
  • 909 Answers
In the printer driver software, there will be an ink monitor, this will, or should flash a low ink warning onscreen when low.
Posted on Oct 05, 2009
Insert cartridge
Check printer cartridge compatibility before unpacking a new print cartridge. Make sure that it is compatible with your printer.
Remove the cartridges and check to make sure the electrical strip along the bottom of each cartridge is not damaged or ripped. If the cartridge is new, make sure the plastic protective tape has been completely removed. Place the cartridges back into the machine and turn it back on.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Sep 04, 2012 | HP Office Equipment & Supplies
Printer says that cartridge needs changing but I have installed a new one
julietr
did you check with another cartridge?
  • your new cartridge might not be good, it might with dried ink.
did you check whether this type of cartridge is copatible with your printer or not.
  • If you are using a different type of cartridge it will not work
Any more question, just Ask me
Thanks
Iqbal
Apr 10, 2008 | Canon MultiPASS F80 All-In-One InkJet...
New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Dec 17, 2009 | Dell 926 All-In-One InkJet Printer
My problem is i have a new cartridge then i was put the printer not detect new cartridge the cartridge is not recognized black and colored. what we do my printer please help me my problem because my n
Take out the catridge and check for the following:
1. At the base of the cartridge where a chip like item is, take off or strip off a glue like label if its on the chip surface of the cartridge.
2. Make sure you place the black and colour cartridge at the right positions.
3. Check the Cartridge bay in the printer (i.e where you place the cartridge in the printer) for the right color description to help you place the cartridge properly.
4. Lastly check the cartridge pack or printer manual to make sure the cartridges are compactible with the printer, else return them to the shop for replacement
May 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Need to take new cartridge back out. It won't budge.
  1. Check cartridge make sure you removed tape covering electrical contacts. do not touch contacts with fingers or metal objects.
  2. Check printer contacts bake sure there is no tape paper or obstruction blocking contacts.
  3. Replace cartridge then turn printer on.
  4. Not working remove cartridge.
  5. using a pencil eraser gently clean contacts with eraser both printer & cartridge.
  6. wipe residue off with a non static lent free dry cloth.
  7. Repeat #3
  8. Still not working try new cartridge the one you have may be bad.
  9. Still not working contact be & we will try something else.
Please rate if fixed or helped. Thank you. Good Luck! I'll standby if you need more help.
Mar 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Color cartridge
Yes, it sounds as if you do need a new color cartridge
Dec 15, 2008 | HP PSC 1610 All-In-One InkJet Printer
Trouble with new cartridge
Sounds like the cartridge is not correctly seated. Try taking out the cartridge, check that it is the correct one for your printer. Then re-insert it. There should be a positive click when it is correctly seated. You can check the 'feel' of this if you still have the old cartridge. You need to be firm, but not rough. Some printers/cartridges are quite stiff. You may need to align the cartridge after re-inserting it. Check the display on the printer and be sure to do the test print if offered. There may also be pop-up instructions on your computer.
Good Luck
Carrieone
Jun 13, 2008 | HP Photosmart 7450 InkJet Printer
Canon printer bjc 85
you need a new printhead, either bc10 for black or bc-11 for color, you also need to check your owners manual to set the printer for the correct printhead type.
Dec 17, 2007 | Canon BJC-85 InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
