Question about Kodak EasyShare CX6445 Digital Camera
Camera not turning on
All of the sudden camera power down and never been on again, lens is still out, replaced batt and clean contacts but nothing. what can I do
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
The lens won't come out or go in
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare One Digital Camera
The lens wont go in and when i turn on the camera, it dies within seconds. how do i get it to work again?
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 11, 2009 | Kodak EasyShare M1033 Digital Camera
My kodak easyshare lens keeps shutting off. the lens goes out and in and off. the camera is less than a year old
Remove the battery
Contact KODAK:
Nov 11, 2009 | Kodak Easyshare V1233 12.1MP Digital...
When turning on camera the lens will open then shut off on a fully charged battery. It will allow you to view pictures on the camera by selecting the favorites and turning it on but when you turn the...
Remove the battery
Your batt. is covered under the same man. warranty as your camera.
Contact KODAK:
Nov 05, 2009 | Kodak EasyShare M863 Digital Camera
Lens doesn't retract
This might be a lens fault and a repair is recommended.
If it also switch off when not retracting then it could also be a no power issue.
You could try following:
Remove the memory card and the battery
Use the camera w/o the memory card
Contact KODAK:
Oct 11, 2009 | Kodak EasyShare V1003 Digital Camera
Lens extends and immediately retracts
If the camera also switched off. Try this.
However hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Remove the battery
Contact KODAK:
Sep 28, 2009 | Kodak Cameras
The lens will not close and the camera will not turn on. the battery is fully charged
Remove the battery
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. Note! Your batt. is also covered by the 1 year man. warranty. :)
Contact KODAK:
Jul 12, 2009 | Kodak EasyShare V1003 Digital Camera
On my kodak camera the lens is stuck
Is there power on the unit? Or does it switch off and then not retract?
If lens issue a repair is needed.
If power issue:
Contact KODAK:
Oct 12, 2008 | Kodak Cameras
Kodak EasyShare CX6445 Digital Camera Logo
90 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
