Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon I have a canon pixma printer. Put new printing heads in but it keeps telling me to insert printer heads and refuses to print. What is wrong? Don
  • bandai82910 Dec 23, 2007
    You sell this junk and want us to keep paying on it forever! Thanks alot for nothing!
Posted on Dec 23, 2007
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer will not print red. The red cartridge seems fine, with ink flowing freely, but it won't print onto the page.
its the problem of print head in your printer. You are not the only one facing this problem there are many other users facing this same canon printer users out of 10 users ---- 8 users face this problem.
Now I will explain the problem
In the printer where you insert the cartridges is called the carriage there is a part called PRINT HEAD. In the print head there are tiny – tiny holes from where the ink passes.when you insert the cartridge in the carriage /head of the printer the ink from the cartridge passes from the head.but if the head is got blocked then the ink will not pass from the head and you get no print out still with the new brand in the printer there is a in built cleaning assembly , so when you give the command of cleaning from your pc/laptop the inbuilt cleaning assembly tries to clean the blocked ink in the tiny holes of the head.but if the ink is got stuck up hard the cleaning assembly in the printer does not have that much power to clean the ink in the head.the other procedure to clean the head is a manual this procedure the head needs to be removed from the printer by disassembling the printer.but in this case out of 100 only 4 to 5 heads gets cleaned and start working but that also don’t last long.its not any guarantee that how much the manually cleaned head will work.
In some cases it has been seen that ink gets used only in cleaning but after inserting new cartridges the printer starts working.if you have inserted new cartridges in the printer and still don’t get any printout then its advisable that you go for any other brand printer.hp is the best brand of printer. Or the other option is you take the printer to local printer repair shop to get the head manually cleaned if you at present don’t want to invest in new printer.a repair center have some special tools to clean the print head its 50 ---- 50 can try that first.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP520 error U051 insert print head, no print head. This is a new printer that was not used for 4 Months. What do I do?
The printer not recognize the print head at the moment.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Clean the contacts using cotton and some alcohol.Then put all back and try again.If this not help you need to replace the print head.It's part number is QY6-0070
Oct 30, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Printer does not print
remove the head and clean it with a tissue paper.and then reinsert.
Dec 10, 2008 | Canon PIXMA MX310 All-In-One Printer
I think i inserted the print head wrong in my canon pixma mp980 printer, how do i remove it?
I had the same problem and this is how I fixed it.
Seems that you can position the print head in the device a couple of ways and the way I did it was wrong. When looking at the print head I could see a white piece of plastic at the bottom of the print head. This piece of plastic was what was jammed and preventing the print head from being removed. I used a small screw driver blade to free it by inserting the screw driver on the right side of the white piece of plastic and twisting it. The head popped out and then I was able to re-insert it.
Poor design by Canon - should not be able to get the head stuck like that...
Dec 05, 2008 | Canon MP520 All-In-One InkJet Photo...
Print Head install
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon PIXMA MP470 All-in-One Printer
Won't print from 3ebk cartridge
i think there is problum in ur cartridge cas adoptor , clean cartridge circuit plate and put cartridge then try
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Correctly fitting ink cartridge/pring head relign?
Here is a link for the user's manual. It will tell you how to correctly insert the cartridges and do a print head alignment.
Just look on the page for the user guide. If this is what you were looking for please rate a big 4 fix ya. Thanks. Need more help? Just post a comment and I'll be back to help you out.
Mar 25, 2008 | Canon PIXMA MP160 All-In-One Printer
Printer refuses to work
You will need pro help with this - so call the man meanwhile browse through this list
May 17, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
