Question about Alpine Televison & Video
After we replaced the trunk latch the remote will not activate the door locks
    President:
  • 1,564 Answers
It is very likely that the latch is not centerd properly in alignment with the catch. The solenoid that drives the locking mechanism is not very strong and requires perfect alignment. You may want to try loosening the holdown bolts a little and closing and opening the hatch a few times then tighten the bolts down again. Thank you, Dana
Posted on Oct 05, 2009
2008 CTS trunk won't unlock
Hi Jeff,
I was going to say, check fuse/ jump the load side of relay Good post.
Mar 19, 2017 | Cars & Trucks
My remote start stopped locking my trunk when I lock my doors. So I have to lock it with the key. How can I fix it back so the remote locks the trunk as well?
Hi Tamika, Im AL the owner of Big As Auto Repair.
Tamika, I'm not sure what vehicle you have but, there are only 2 styles of trunk lock actuators. (1) Is built into the latch itself and if you have this style the latch will need to be replace. (2) The other style will have a rod running from the latch over to a lock actuator, with this style you'll need to replace the lock actuator. NOTE: With either style, you'll first need to make sure you have power and ground to it, and if you have both power and ground then it needs to be replaced. If you do not find either power are ground you'll need to find out why and repair that problem. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Dec 28, 2015 | Cars & Trucks
Tailgate door wont latch
IT sounds like you closed the Trunk/ Liftgate with the Latch partway closed. Lube the Latch and hopefully it is not bent. If it is not latching, you can try and ensure it is aligned propery (use a piece of Tape and see where it is hitting the STRIKER...
If not, you are going to be replacing the Latching Mechanism.
Apr 06, 2013 | 2009 Honda CR-V
The trunk lock latch is in the lock position in the trunk and the key will not open the trunk in a 1994 pontiac grand am
Often,the trunk latch does not get lubricated enough(I can tell you from my dealer tech experience that places like Jiffy Lube NEVER service the body latches).Try pulling the release handle while some else "slaps" the trunk lid.This usually works on the hood,trunk,and remote fuel door release.I would see many Grand Ams that were only 2-3 years old with these problems.
Feb 24, 2012 | 1994 Pontiac Grand Am
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
My trunk will not close
There is a possibility that the remote latch cable is stuck (lubrication is gone) . With a screwdriver, NOT the fingers, try to return manually the latch, to its open position (instead of the pull open position). If you push it too far, it will go into locked position, and when you pull down the trunk lid, it wont reach its normal closed position. In that case, pull the latch back open, with the remote lever. Should you manage to close the trunk properly, spray some WD40 or some lubricant on the latch assembly.
Apr 24, 2010 | 1998 Honda Accord
Trunk release switch does not work
1) check trunk fuse
2) check if there is voltage at the trunk latch and that you can hear the solenoid at the latch activate.
3) if voltage present and solenoid does activate. Try lubing the latch. May be binding.
4) voltage present, solenoid activates, latch lubed. trunck still does'nt open. replace solenoid
Mar 26, 2010 | 2002 Oldsmobile Aurora
2007 Saturn Aura; when trying remote start horn beeps three times but doesn't start. I've replaced battery. Other functions work fine - door locks, trunk opens, alarm arms. Other key fob works fine.
press the lock button on the remote then press the remote start button. if this does not work check remote start status using steering wheel buttons
Jan 03, 2010 | 2007 Saturn Aura XR Sedan
New batteries but remote won't click the door(s) or trunk. Ron
try programming the remote again, here is how u do that. if this doesn't fix the problem the remote may be defective, if you need a new one try ebay, they are very cheap to buy there.
Note: Existing keyless remotes will be erased with this procedure.
Existing working remotes will have to reprogrammed also.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
Nov 30, 2009 | 1994 Pontiac Grand Prix
Door locks not working properly.
one of the front door latches is out of adjustment or bad. when you lock it at the trunk try the front doors to see if they might still open when the alarm is set if so that is your bad latch. bad news is to replace it you will need to tear down the entire inside of door
Mar 24, 2009 | 1998 Audi A4
Televison & Video Logo
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
