Question about Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V "cannot play"
Normal DVDs and CDs stopped playing completely.
display reads "READING" followed by "CANNOT PLAY" before moving onto the next disc. using the same DVDs as i always have, just one day stopped working. Manufacture date is Sept. 07.
took off cover to see what i could see. found out that the DVD loads fine into the laser assembly but fails to spin the disc. I have to assume that this is just a drive failure and that it needs to be replaced.
Any other thoughts or solutions to try? if not how do I go about ordering replacement parts and price would be helpful.
thanks
You can clean the motor by the back side
Posted on Apr 09, 2010
Spindle motor is bad...MUST be replaced.
Posted on Mar 04, 2010
  • dinoferino Jun 23, 2011
    where can u buy a spindle motor?
SPIN DVD FOR 2-3 SEC AND COME OUT BACK AND SAY NO DVD
Posted on Jun 11, 2010
I have a Sony DVP-CX995V DVD player that will play CDs but won't read DVDs. Any ideas as to what might be the problem and if its an easy fix?
absolutely nothing with these electronic gadgets is easy and most are not cheap to fix . it might need cleaned if you are lucky
May 30, 2015 | Sony Televison & Video
The player is playing cds get error message that it can not play dvds
hello,
the problem of the layer is that the strength the lense needs to carry out work on a DVD is not enough, therefore the lense is weak, though it plays cds, cos the strength needed to play a cd is low.
the solution is for you to unscrew the player, detach carefully and disconect the old lense, and replace with a new lense. screw it back and make sure there is no tampering with any of the wires, then test it with a DVD cd.
Jan 04, 2010 | Sony DVP-CX995V Multi-disc DVD Player
SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Aug 14, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVD player DVP-NS30 does not play dvds
Change the motor disc spindle,good luck
Jun 07, 2009 | Sony DVP-NS57P
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
SONY DVP-S7000 does not play DVD
The laser head has probably just got dust on it, get a cleaning disk.
Jan 14, 2009 | Sony DVP-S7000 DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
Sony DVP-CX995V Multi-disc DVD Player Logo
2,035 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
