No signal I installed the coixal cable in to the ant.port.Iam getting no signal on screen.Help
  • 909 Answers
Stupid question.....is the other end connected to an aerial??? if it goes to a box on the wall, is the box connected to an aerial??? if you have or can use a vcr, connect this and put in an origional tape that you know works, start the tape and tune the tv to the vcr signal(if the tv will tune into analogue) and this will tell you if the tuner card is at fault.
Is the tv digital or analogue?? if digital and analogue, are you sure you are tuning on the digital/analogue settings.( I don't know where you are in the world to give more advice, and as the analogue service has been switched off in my area,S.W England, perhaps it has been turned off in your area also)
Posted on Oct 05, 2009
  • 647 Answers
Try video input using a dvd - if you are using a digital cable box (or satellite) use the a/v outputs (yel red wht wires)to hook to video in of TV. If you are using standard cable hook the cable through a vcr if available and hook the a/v of the vcr to video in of the tv.
Otherwise is tv(to be used) on Ch3?
The TV tuner may be defective.
If this helped Vote/rate me.
R4212 indicates "no Signal", on Ant or cable...both ant and cable are good and work on other tv's.
If the input is set to cable or antenna and you don't get a signal I'd replace the main board, you could try using the AV input and see if that works if your using a cable box.
Nov 14, 2017 | Televison & Video
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
No signal -Samsung HC-R4755
Well Dave have a tech come out and solder your ANT1 connection back on its a simple job that will probably set you back $50.00 or less.
May 31, 2010 | Samsung HC-R4755W 47" HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
TRYING TO INSTALL MY EASY CAPTURE BUT KEEP GETTING NO SIGNAL HELP
click on "options" icon in the center of the screen. change the video input to a diff. source
Mar 07, 2009 | Ulead Videostudio 8 for PC
Driver software
please try this out in other systenm and see of the problem is with the USB port of ur system
Dec 16, 2008 | Cell Phones
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
