Question about Olympus Camedia C-350 Digital Camera
Flash Setting on camera
When I take a regular picture sometimes it comes out to bright and I have not touched the settings, mostly because I don't know the settings.
  • 148 Answers
Time to bite the bullet and read.
flash is probably the most difficult thing to master in photography. and usually high end camera manuals are smaller than the manuals for the flash units that they use.
over brightness is a result sensor settings. if the camera is looking at a dark area, it will ask the flash for more light. so, see if you are using spot metering, which lets you pick a small area of the subject and set the light and exposure for that area. if it is, then be careful where it is pointed. if you are set for a more broad metering, your camera will call for an averaging of the area probably nearer the center, but take into consideration the entire frame. the book will guide you as to how the camera is set to 'see' the subject.
read, read, read. its not really hard if you take a little at a time.
good luck
Posted on Dec 23, 2007
My canon powershot s3 IS is taking really dark pictures. The only decent pictures I can take with it are outside in sunlight. Pics indoors come out dark and grainy. I flip up the flash, but most of the...
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
Jan 04, 2011 | Canon PowerShot S3 IS Digital Camera
Bad pictures on my Digital Camera
A digital camera is a wonderful device - it's just not as good as the human eye yet.
Some things to watch out for:
Spots in the picture - Shiny surfaces reflect your flash back to you.
Picture is dark - Bright Window behind your subject - . Use backlight setting.
Bad focus - Subject is not in the middle of the picture. (Use focus lock if you have it)
Colours don't look right - Sunlight in a building with overhead fluorescents.The camera does not know to use the fluorescent light setting. Set it.
Picture is clear but dark on an overcast day - sport setting is ON or the ISO is too fast. Use auto, 100 or 200.
Flash won't flash and subject comes out dark - light behind subject. Set the flash to 'Always' for this picture.
Do's and Don'ts
Don't drop the camera. USE the hand/neck strap.
Don't store pictures on your memory stick - make copies as soon as you can.
Don't make changes to pictures with your computer while they are on the memory stick. Work with copies on your computer.
Do not allow rain to land on the camera - rain easily runs inside.
If you use rechargable batteries - have two or more sets. Use one set until they are used up, then switch. Charge the low battery only. This maximizes the battery life and provides the longest operating time.
Clean the battery contacts in the camera two or three times a year with 99% pure alcohol and a cotton swab. It does not hurt to clean the ends of rechargeable batteries at the same time. Don't touch batteries on their ends.
on Mar 29, 2010 | Cameras
My daughter can't take pictures outside as the flash goes off and it just gives a white picture as it's too bright, what can I do?
1. You could try pressing the reset button. 2. You could press the "delete" button to change the flash mode when you first turn the camera on. 3.=Please check your flash setting to make sure that you don’t have the camera on forced flash mode (indicated by the lightning bolt with the plus sign in the upper right corner).
Using this setting in strong lighting conditions would result in a picture with too much
4. If all else fails, you can call 1-800-521-2010
Aug 17, 2010 | Vtech Kidizoom Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
How do I set the camera to Macro and can I turn
Page 16 of the user manual explains how to set up the camera for the macro mode. If you are using regular macro mode then you would also need to set the flash mode to off if you do not want it to fire automatically (page 15 of the user manual refers how to disable the flash). If you are using the super macro mode then the flash would be set to off by default.
May 02, 2009 | Olympus Stylus 770 SW Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Bright pictures
It seams under warranty, ask to Sony, they will replace it with new one.
May 29, 2008 | Sony Cybershot S650 Digital Camera
Camera Flash & Picture
I just got this camera for Christmas the only way that I know of how to fix it is to change the exposure manually. If the picture is to bright you need a negative exposure, if it is to dark you need a positive exposure. I have noticed that the auto exposure does not get the correct setting that you need for the lighting.
Oct 11, 2007 | Polaroid A500 Digital Camera
My picture is too light (overexposed).
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
