Question about IBM Infoprint 1332 Laser Printer
Using 1332 on ip network. When printing from web, get an extra page with "@PJL SET RESOLUTION=6002PJL ENTER LANGUAGE=PCL" How do I get this to stop?
    Brigadier General:
  • 3,614 Answers
First make sure that the printer was properly set and has to be your default printer, also if you haven't install the printer driver you also getting this problem.
Hope this helps
Let me know for any clarifications,.
Posted on Oct 05, 2009
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
OKIDATA 490 printers started printing the following and there were no changes made to any software/network/hardware. The emulation is and has always been Epson LQ - ''12345X@PJL @PJL INFO PAGECOUNT...
We had this same problem and discovered that some vendor installed a program called "Print Track" which discovered every printer on the network using port 9100 and sent a query for how many pages were printed. Removing this software from the offending PC resolved this issue. We used the "job log" from one of the Okidata printers to find the IP address of the PC that was causing this.
Jul 07, 2009 | Computers & Internet
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
LaerJet 5p Extra page prints with code
check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Oct 28, 2008 | HP LaserJet 5p Printer
LaserJet 5p extra page prints first with code
When you get that kind of information those are instructions to the printer. It has been my experience that the drivers loaded for the printer are not the correct ones. Check to make sure that you have the drivers for a HP 5P printer and verify that is what kind a printer you have.
Amber light that is a triangle is blinking and printer will not print any suggestions as to what is wrong
if you press the orange(big main one) flashing button and it prints 1 page , the you have the paper size set wrong .....check your paper size settings , it comes as default letter , here in the uk we have to get the network guys to change the default to a4 ,
go to hp website and download the manual (the last one in user guide section )
HP PCL/PJL reference (PCL 5 Printer Language) - Technical Quick Reference Guide
here is the web page http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=uk&docIndexId=64902&taskId=101&prodTypeId=18972&prodSeriesId=388394
its has all the light codes there too .
Aug 21, 2008 | HP LaserJet 2550n Printer
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
IBM Infoprint 1332 Laser Printer Logo
78 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
