Can you explain please why after switching off all power to my tv, video and dvd for approx 20 minutes, I am now unable to get a picture,sound or any signs of life from my tv screen - as far as I'm aware both the dvd and video are ok but I am unable to see either due to a blank tv screen
  • 647 Answers
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 05, 2009
My TH-50PX70A Plasma TV, has lost its picture and only has sound. When you turn it only the green power light flickers on and off rapidly (approx 15-20 times) the TV switches on to a dull black and the...
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
Jan 13, 2011 | Panasonic TH-50PX70 50 in. Plasma TV
TV STAYS ON WITH SOUND AND PICTURE FOR ABOUT 20 SECONDS .THE SOUND AND PICTURE GOES OUT FOR APPROX. MINUTE ,THAN THE SOUND AND PICTURE RETURNS .THIS PROCESS HAPPENS OVER AND OVER
It is symptom of weak lamp that has been reached to end of its working hours life and need to be replaced to solve this problem.
Replace lamp in your tv, procedure is easy and would be written in your tv user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Nov 21, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Screen won't display
I found your site confusing. If you had read my post, you would have noticed that my problem referred to a 15" flat screen 'CELLO' .TV/DVD combo. I had sound but no picture. When switched on, the screen lit up and the word CELLO appeared then the sreen went black
Nov 25, 2008 | Emerson EWF2004 20" TV
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv wont turn on.
try cutting power off and wait 15 to 20 minutes. also try another outlet depending how much power u r pulling thru the outlet u had it in. Had same problem and customer service said unplug for 3 min....not long enuf...so try 15 to 20 min and plug back in.
Apr 10, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Oct 05, 2007 | Televison & Video
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
