Question about Vacuums
Manual I need a manual for an Everstar Canister Vacuum 1200
Need filter everstar vc 9550
I'm needing a filter for my everstar 3 stage heap vacuum model bck 9550, do u know where I can purchase one?
Oct 27, 2013 | Eureka 431A Optima Bagless Upright Vacuum
My vaccuum cleaner is an EVERSTAR 1200. I turned it on - everything appears OK until I realize that it is not suctionning. I cleaned out the canister - made sure the vacuum was not obstructed. Still no...
First clean the filter on top of the canister, do not wet it, blow it and get all the accumulated dust out. Then check the hoses for obstruction. There should be an emergency valve on the rear part, if it is open, you better ck the hoses.
Aug 29, 2010 | Vacuums
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
We have a Everstar Turbo Vac. 180 and so far its been wonderful.. All of a sudden it became really loud and spitted out the debree. took it to a vac. repair shop and he wouldnt even look at it! Any...
I found my Everstar near a neighbor's trash. I was going to look for another vacuum cleaner for my third level so I wouldn't have to drag my heavy cleaner up and down the stairs. I was totally and pleasantly surprised at this vaccuum cleaner. It had better suction than my dyson. Granted it is kind of a pain to pull out the dirt from the plastic canister but I got used to it. Then one day it just stopped. I know that when the Dyson stops it means something is stuck or clogged and you have to wait for the motor to cool down for it to start again. Same thing happened to the Everstar. It started again. I took the top part where the filter was and found the filter to be incredibly filthy. I washed it, dryed it and put it back and that was the cause of the problem.
Apr 24, 2008 | Vacuums
Need to buy parts
Per the Manual I received with my vacuum.... try e-mailing Home_Depot@Eup.cn
Mar 06, 2008 | Vacuums
Vacuums Logo
241 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
