Question about Kyocera Mita KYOCERA/MITA AS-M4110 Copier
Kyocera mita maintenance light is on and lines
Kyocera mita km 1530 maintenance light is on and lines through copies
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Well, DUH..Put in a Service Call
  • 622 Answers
Check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Posted on Dec 23, 2009
  • 523 Answers
Maintenance line is on, means it is the time to change the kit of your machine, this usually happens after due of the first kit which is couple of thousand, and the line on the copy could have more than problem, it could be just the small split class needs to be cleaned, or could be harder for example: Drum, Fuser......, let me know exactly the type of line and i can help. am Kycoera certified Tech.
Thanks for using Fixya
Posted on Oct 06, 2009
  • Kyocera HP Expert Oct 06, 2009
    Maintenance light is on means it is the time to change the kit of your machine, and the line in the copy could be easy like cleanning the split class, or hard like changing drum or fuser, let me know where is the line exactly, vertical or horizental, does it change its place, what if you make copy from class? am kyocera certified Tech and i can help you fixing your problem.
  • Joao Branco Sep 16, 2013
    I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already ... ?
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
Km 1530 displaying ap on screen
Please click here to download the technical guide and user manual.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM1530._.EN.html#
Sep 06, 2012 | Kyocera Mita Office Equipment & Supplies
Dear sir i need to service manual for mita km-1530 with regards oskooie
pls go on this site
www.azmanual.com/manual/.../kyocera-mita-km-1530-manual
Dec 12, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera mita km-1530
press 1087 1087, then 131, press copy and then set toner level to 155. turn off machine and on again.
Mar 17, 2008 | Baby Gear
263 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
