Question about RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 keeps turning off
The RCA HDLP TV works with no problems then all at once the power light flashes 5 times and the picure goes black...a minute or two later the picture comes back on. I have tried re-seting the TV by unpluging, it works for a while then the problem comes back. 6 months ago I had to have the color wheel and lamp replaced.
  • ronnie07 Dec 23, 2007
    I also have the power on and off issue. First, the TV
    was bought in 04, and I had the bulb replaced in 06. For lamp problems, I
    found out this was due to power outages. The lamp needs to cool down, and
    with a sudden lose of power; it seriously degrades the lamp leading to eventual
    failure. I bought a surge/battery back-up from RS for this issue,
    40 bucks gives me 5 minutes of cool down or the ability to turn the TV off
    during a power loss.
    Now recently, the TV all of a sudden powers down, and turns
    off, with the power button on the TV blinking.
    Reading trouble shooting in the user guide listed a few possible causes,
    but the only thing I could attribute it to is a voltage issue. But with the surge protection I have, that
    shouldn’t be an issue? I’m perplexed.
It was a voltage issue for me. I had major voltage fluctuations. I got a good a battery backup, voltage line regulator for about 200 bucks, problem solved.
Posted on Jun 07, 2008
  • 3 Answers
I had a set with a similar issue--at first the tv would suddenly turn itself off, sit for a moment while flashing the power button, then "reset" itself and continue running.
Then one day it quit starting up all together. I couldn't get a picture at all. I was hoping it just needed a new lamp (which is what I was able to gather from reading various troubleshooting forums).
I took it to a repair shop for a definitive opinion, and when they took a look at the TV it actually started smoking and the issue was definately the light engine, not the lamp.  Unfortunately, a light engine repair costs around $950.  If you try to do it yourself, the part costs about $700, if it is in stock (and it turns out that it often is NOT in stock).
Instead of putting that much money into this TV, I'm going to have to bite the bullet and get a new TV.  It just doesn't seem a good use of nearly a grand when new HDTVs can be had for around $1300.  Sorry for bad news.
If you can, try to replace the light first. You can get just the lamp for less than $200, although it may be a larger issue like mine.
Posted on Jan 08, 2008
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 2003 rca big screen, D495Cd05V serial #, HDLP50W151 model #, 4103067310297 lamp, 260962 part#, 50W151YX1 service number HDLP... the tv works an turns on but u cant really see the screen that great...
If the picture is dark you will need to replace the projection lamp. Make sure before replacing that the TV has been turned off for at least an hour as the lamp does get very hot. Just do a google search with the lamp part number of 260962 to find a decent price for it. Be careful as some will be just the bulb and not the complete assembly. I suggest replacing the complete assembly as replacing just the bulb requires gloves and being very careful handling the bulb assembly. There is an access door on the lower right side of the back of the TV where you can get to the lamp. Make sure the TV is unplugged and once you put the new lamp in make sure the door is placed back in correctly otherwise the set will fail to light the lamp. Good luck and I hope this helps : )
Jul 25, 2011 | RCA Televison & Video
Were can I buy a "light engine" , part number 26589 for a hdlp 50w151 television ?
26589 This is the actual part, which they have none of...but on this page they say this part can replace that one fine: 261589DX
Aug 05, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Picture flashes off but still have sound
You may want to change the lamp. It may be on the edge of failing totally.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA Scenium HDLP50W151
Color wheel bad #212184
Approx $400 by an authorized RCA shop
Dec 31, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
231 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
