Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
My craftsman 917.273621 starts and runs. But, turns off when i pull on the Pto. The bets engage then kills the engine. Help me please.
  • 389 Answers
First thing to check would be the safety switch under the seat. Check to see if it has come partially unplugged. If it appears to be a good solid connection you can check the switch by temporarily unplugging it and using a short jumper wire to jump across the 2 wires in the plug. It it then works properly, replace the switch
Posted on Oct 05, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Engine will not start. Jumped out solenoid and engine starts but kills when PTO switch is engaged to operate blades. Any ideas?
yes but whats a 12 volt light bulb do that connected across the start solinod when the key is turned to start ?
id bet it don't lite! this is proof theres a high resistance fault in one of your safety switches (very common)
Sep 15, 2015 | Garden
I have a husqvarna riding mower.. when i engage pto it kills the mower.. i direct wired the pto to the battery and it kicks on and off while mowing, mower runs fine when the pto is off please help
If you wired the pto directly to the battery and still kicks off and on, you have a bad pto clutch. They can be expensive but they are fairly easy to replace. Hope this helped.
Sep 07, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
I just recieved craftsman lt1000, 19.5 b&s, 42 in. cut with hydrostat that was fine but I think I tripped a kill switch and it won't even try to engage the starter. What kill switches are there beside...
You didn't indicate what model number you have. You can download a manual here:http://www.managemylife.com/mmh/owner_manuals/21205/CRAFTSMAN-Lawn,-Tractor-L0306104?brand_name_search=917272672+CRAFTSMAN if the 917272672 isn't the right model go to www.searspartsdirect.com and enter you model number. When the parts come up look over on right had side of page for button to select manual. To start, you must have foot on clutch, PTO disengaged. The seat switch doesn't come into play until the PTO is engaged. Check for voltage at the B terminal on the start switch to be sure fuse is good. From there check the S terminal when you turn key to start. From there it goes to the clutch/brake switch (when depressed) then to pto clutch then to solenoid. GOOD LUCK!
Aug 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Jul 04, 2010 | Craftsman Garden
PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
