Question about Cameras
I want a blurry background in my picture, can i do that with a G9?
2 Suggested Answers
  • 3 Answers
SOURCE: Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Posted on Jul 17, 2009
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
The camera Canon G 9 bought in late 2008, was dropped to the tile floor from about half-meter height. After that, no defects in functioning except the focus. The auto focus is not working properly, the...
Hi Pavel
Sorry but your camera needs to have the lens replaced. The drop onto the floor damaged it and the only way to fix it is to replace it. Wish I had better news for you.
Thomas Drayton
Owner Darntoothysam.com
Affordable Digital Camera Repair
Jun 10, 2011 | Canon PowerShot G9 Digital Camera
Everytime i put a picture for the background on the desktop it doesnt come out clear its all fuzzy/blurry anyone know what's happenin?
It's because your resolution(size) of your desktop is larger than the resolution(size) of the picture. If for example you are running a resolution of 1280x1024 then a picture with the dimentions of 1280x1024 would fit perfectly and not be stretched. See my tip on setting the desktop background here for further details: http://www.fixya.com/support/r6775332-change_desktop_background_image
If you want a smaller image to be centered and not stretched then right click on your desktop and go to Properties. Then click on the Desktop tab. To the middle right there is a heading that says Position. Click the little selection to Center. This will center a smaller image instead of making it all blurry and stretched.
May 27, 2011 | HP w1907 LCD Monitor
I own cannon G9. I fail to get good sharp open outdoor pictures at night especially in place not well lighted. Do I all the time have to take pictures Manually to get sharp pictures as we do with focus...
If you have tried using the auto setting and it is still doing the blurry pictures it sounds like a problem with your camera not the settings themselves.
This blog http://www.teleplancamerarepair.com/camera-repair-blog/post/Got-Blurry-Pictures-Blurry-Image.aspx suggests a couple of the reasons might be:
"When your image appears distorted and with altered colors, in most of the cases there are two possible reasons:
- The internal shutter gets stuck , does not open completely or
The image sensor is damaged.... "
Jul 01, 2010 | Cameras
Blurry picture
Jun 09, 2009 | Logitech 961462-0403 Webcam
Bakground of the photo is a bit blurry
this is, in most cases, a desired effect (bokeh) which is used to "detach" the subject from the background avoiding the viewer of the picture to be distracted by the background. This technique is widely used in portraits. This effect effect will be more pronounced when the lens is wide open (in your case it should be f/3.5 if I remember well...). To practice you may try the following: set you camera to "A" mode and take one picture of something (it should not be a landscape) using the smallest aperture after this take the same pic using the biggest aperture. With the lower f number you should get a blurry background and with the biggest the backgroud should be in focus!
May 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon powershot s3 is digtal
This is a menu setting, in capture mode it is the slow synchro option I think. What it does is try to get the subject to have a lit background. Turn this off and you get a subject lit with flash and no background but no blurriness either.
Jul 11, 2008 | Canon PowerShot S3 IS Digital Camera
Picture problem
Turn off the slow synchro function and the blurry on indoors with flash will stop.
Jan 02, 2008 | Cameras
Blurry Background
Not all the Rearprojections have same picture. Some you must watch at angle to get clear picture.
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
