Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
My Prisma SE24 LPG boiler will not light, it trys to ignite but nothing happens. I know there is gas as the cooker works fine.... I have tried the control knobs all ways but nothing happens. Can you help plz?
    Champion:
  • 248 Answers
Therma coupling check for lint check fan
Posted on Oct 12, 2009
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Prestige 110 boiler won't ignite
Is there gas cause most of the time it won't ignite cause there is no gas. What you can do is light it your self and if it lights that is good and if it stays light than there is has sometime you have to light it your self
Problem with IGNITION LOCKOUT
Air in the system or low gas pressure?
Apr 25, 2013 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
How do I light my pottertn kingfisher pilot as its gone out? Keep pusing the ignite button but nothing is happening
Push also the gas button and hold in until pilot lit and then for some seconds [8-30] after until the thermocouple is hot enough to tell the boiler to light the main burner
Dec 16, 2009 | Stiebel Eltron DHC Instant Tankless...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
74 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
