Question about Dell S2500 Printer
Dell S2500 doesn't recognize loaded paper. - Dell S2500 Printer
  • 68 Answers
Pull the paper tray out and check if the paper end sensor is out of bracket or broken.When you remove the paper tray and look inside,you should be able to see the sensor lever that can be moved up by finger.It moved up by paper stock when you insert the tray.This is how paper detection mechanism works on majority of the printers.
Posted on Oct 05, 2009
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
PAPER JAM
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Dell S2500 Printer
It is not picking up the paper
your pick-up roller is most likely dirty. the two solutions are simple. 1) replace the roller, and 2) first try to lick your fingers and rub the roller.
Nov 11, 2009 | Dell S2500 Printer
Dell 924 Photo Printer will not recognize that paper is loaded
you will likely have to take this in for (hopefully free!) warranty service. it sounds like there was an assembly issue here. good luck!
Feb 17, 2009 | Dell 924 All-in-One InkJet Printer
Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Mar 14, 2008 | Dell S2500 Printer
Sensor
Hi, More than likely it could be the paper sensor !!! It recognizes the tray has paper and when the tray is loaded with paper. My suggestion for any dell printers are to take them to your local dump and get rid of it. The only reason I say this is because dell makes these printers where the parts are impossible to get and when you can find them your better off buying a new one!! I know it's frustrating but my suggestion is to try Hp or a diffrent MFG!! Good Luck! Thanks
Dec 04, 2007 | Dell 924 All-in-One InkJet Printer
Dell S2500 Printer Logo
120 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
