Question about Electronics - Others
Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
Fresh out of the box, trying to pre-load some pictures for a Christmas gift. Connected via USB, new hardware installed successfully. Looking under "My Computer" for the removable disks...several are listed (I believe they correspond to the different memory card slots available on the Frame) but unable to locate the one that corresponds to the internal memory. Each time I click on one of them, it says, "Please insert disk into Drive _" I have attempted this on two different computers, different USB cable, even tried another Picture Frame (I bought 2). Same problem each time.
    Problem Solver:
  • 5 Answers
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
Posted on Dec 19, 2009
Can't get it to switch over to USB or mmc how do I do that to load my pictures
I'd recommend putting the pictures on the memory card and inserting it into the digital frame first, them power it on. It should automatically load that way.
Jan 19, 2015 | Coby DP-768 7-Inch Widescreen Digital...
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
Hi, I purchased 3 Coby digital frames DP 700 with the intention of putting vacation pictures on for three friends. The included directions are useless. Hope you can help. Can I transfer and SAVE...
Good day,
I read up on the specs of the frame and it does not have an internal memory, thus you will have to have the sd card inserted at all times to display photos.
Hope this helps!
Regards
Dec 01, 2010 | Coby Cameras
I don't know how to make my picture frame do the
restart the whole process and redownload the pictures maybe it should work then
Mar 14, 2010 | Coby DP-772 Digital Picture Frame
Colby DP702 photo frame
DP 702 photo frame -- trying to move music from ITunes to my photo frame -- how? Any help would be appreciated ;) Jeane
Jan 03, 2010 | Coby DP-772 Digital Picture Frame
Delete pictures
i think to unlock or unwriteprotect it to enable to format or delete a file....
Sep 01, 2009 | Coby DP-772 Digital Picture Frame
I am having a problem with my digital photo frame DP-352 do you have to keep the usb or memory card from your camera in the the frame at all time to see pictures or can you download them
you can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
Aug 14, 2009 | Coby DP-772 Digital Picture Frame
Unable to load more than ~50MB into df780 digital picture frame
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
Jan 07, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Have a kodak ex811 digital frame
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once you connected your EX811 to your computer, and get the message “Use PC interface to copy files.” That means you can start copying files. Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Oct 27, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
Electronics - Others Logo
344 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
