Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Starter recoil spring attachment. It clips into the cover at one end but I cannot see how it attaches to the hub of the pulling wheel
    President:
  • 2,220 Answers
An IPL for a Oct 2004 455 can be found here:
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401113.pdf
There as a starter detail page but it may not answer your question.
I bend the inner portion of the recoil spring until the center hub can engage the retaining device located on the inner end. The inner end of the spring passes through the hub and a small ring retainer and spring tension keeps it in place. You will need about 2 revolutions against the spring for the recoil to operate properly. HTH
Lou
Posted on Oct 07, 2009
Replacing pull cord on tallon chainsaw
This is not too difficult. Remove recoil cover...wind the spring back up carefully and line up the hole for new recoil cord. Secure it so it does not let loose. It helps to heat the end of the new cord and twist it so it has a point on it. Run it through and tie a good knot. Release coil spring SLOWLY until it has stopped. Attach the pull handle and cut away.
Feb 02, 2018 | Garden
How do you get drive shaft apart to get to starter rope?
Hi Donna:
Most of the pull start assemblies are attached so that their centre is directly over the centre of the driveshaft. There will be several bolts that connect the assemby to the engine, and when they are removed, the pull start assembly can be lifted off.
If you turn it over and look at the underside, the cover for the spring and rope will be attached, possibly with pop rivets, or it may be held in place by a centre bolt.
Patience and caution will be your friends as you determine how to dis-mantle it.
If the spring is broken, see if you can get some tips from the service people where you buy the replacement.
May 09, 2015 | Garden
I have a Ryobi Expand-It 2 Cycle 26cc Trimmer , and when i attacthed the pole trimmer and tried to start it the pull cord won't retract.. do you know how to fix this? i can't get the cover off
the ryobi expand-it is just a power head ( motor ) that you can attach any ryobi or like attachment to
There is no reason why attaching a pole trimmer would affect the recoil of the starter rope as it just slides onto the drive at the end of the shaft
the fix will require the removal of the cover and the tool will be in a selection of bits that you can get from a good tool shop or auto parts shop
from memory it is a 6 point star around 3mm in size
the failure to recoil is normally a broken coil spring
Oct 30, 2017 | Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How do you get the starter rope to rewind after pulling to start my 25 cc poulin pro trimmer? How do you access the recoil spring?
    The starter rope normally rewinds automatically when the recoil unit is functioning properly. If the pull rope has stayed out, disassembly will be required. Here are instructions for that problem. The recoil spring can break and is replaceable, but the nylon hub in the starter recoil unit is usually the problem or the rope has broken and jammed inside.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Here are more details for servicing the starter/recoil unit....With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are doneervicing the recoil unitl
    Jun 04, 2011 | Poulan Garden
    Starter rope on UST generator got behind wheel. Took cover off and spring unwound. Rewound spring inside starter rope wheel. Every time try to wind rope spool back inside cover and replace, inner spool...
    Hi, W/D here.
    Go at it from the other end. Take the handle off of the rope. If you have a fine piece of wire, attach it securely to the handle end of the rope; you'll use the wire to feed the rope back through in a moment. Wind the spring and starter wheel. When it's getting about as tight as you want it, align the knot hole with the shroud grommet. Feed the pull rope and wire through the knot hole, and out the shroud grommet, and pull the line all the way through, down to the knot. Catch the free end and put a slip knot in it, so it can't whizz on back into the reel. Attach the pull handle, and release the slip knot.
    Best regards, W/D
    Feb 13, 2011 | UST GG2300 Portable Gas Powered Generator
    Re attach coil. is there an easy way
    winding it in is the only way to put the spring back in the housing. Start with the outer end, and wind to the inside, until all the spring is seated in the housing..Now...the wheel sits in the center. There's a hook on the spring and it mates to a tab on the recoil wheel when it's put on. No locking in place required, it'll stay in place from the spring tension as it wraps around...once the wheel is in place, start turning (winding up) the wheel in the same direction as if the rope was pulling on it. Keep winding til it stops, and hold it there. Slowly let it back up until the hole in the wheel (where the knot will be) is aligned with the hole in the housing where the rope goes thru. have a friend feed the rope thru the hole in the housing, thru the hole in the wheel, make a knot, and tuck it in the slot. Keep holding the wheel, and attach the handle to the other end. Slowly let it go until the rope winds in as it should...Done...
    May 31, 2010 | Garden
    Doesn,t engage with engine
    sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
    Dec 26, 2009 | Toro Garden
    The recoil on my sears model 917.377610 is stopped recoiling. Looking for some help yo get it apart and fix the problem. I cannot get it off the engine
    This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
    First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
    1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
    2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
    3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
    4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
    5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
    6. Put the blower housing back on and your ready to start the engine & mow.
    Apr 19, 2009 | Garden
    Broken starter cord lawn mower #944.368300/craftsman
    Please note ! patients is required with this one !
    Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
    Remove old cord.
    With your new cord lace it through the recoil spool centre hole with a knott on the end.
    now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
    Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
    Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
    But hold the spool firmly untill the cord has a good knott on the end of it.
    (Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
    Sep 09, 2008 | Garden
    Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
    233 people viewed this question
    Top Husqvarna Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
