Question about Bialetti Mukka Express
It has never worked. Leaks where top screws into bottom. I have scewed it as tight as it goes. I have seen others describe a gasket. Mine didn't come with a gasket. Should it have?
If you had a gasket and it still leaks, try rubbing a little cooking oil on the gasket with your finger to improve the seal
Posted on Apr 03, 2011
  • 22 Answers
Of course you should have it otherwise it can't build up pressure
Posted on Oct 28, 2009
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
I have a 30 year old TriStar (bullet style with thick bumper gasket around the middle) and the High/Low speed switch is burnt out. I am trying to find instructions for how to separate the shell to get to...
you remove the screw up front and the 2 scews buy the the rewheels from the bottom and then you pry the shell apart from the gasket it is tight but once you get it to loosen it come easy
Feb 25, 2010 | Vacuums
5 year old wash machine leaks as the tub fills with water out the bottom somewhere. Hot and cold hoses are tight, drain hose is tight. This machine was just moved from one location to another. What could...
your tub seal between the top of the transmission and the wash tub, or the fill tube hose to the load size control may have a hole in it from the lower tub to the control panel on top
Oct 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Leaks when dispensing
get out the phillips head screwsdriver and take it apart a bit.... search online for more details, but i've seen several posts for several models where people had to go 'in' and tighten up some screws. either that, or they discovered cracked plastic pieces (which you'd then have to have replaced, or return the entire unit).
sorry, i have no further solution, but thought perhaps this might point you in a direction??? good luck.
Oct 31, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Bialetti Mukka Express Logo
512 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
