Question about ViewSonic TPCV1250S (TPCV1250S0103) Tablet PC
1250S Display problem
Hello-
My 1250S has a problem with the LCD display. When i turn on the PC there is no problem but after about 10-15 minutes the backlight goes out...I can barely see it but the LCD's still work but without the backlight its almost impossible. After i turn off the computer and turn it back on, the LCD is back to normal with no problems. Is there anything I can do about this?
    New Friend:
  • 3 Answers
Aqib mumtaz for sale 2$
Posted on Dec 03, 2013
  • 21 Answers
It sounds like the system is trying to reduce power consumption to save battery life. Check your power settings in the control panel and set them to Max Performance to see if it stops doing it. If it does, you know that was the reason. If it doesn't let us know.
Mike Vail
Posted on Oct 05, 2009
Tablet wont stay on
Check the display settings and the power settings.
The display.
You can set for 5 minutes the default is usually 30 seconds.
The power settings.
Make sure it is not in savings mode an turns off the display very quickly.
Some battery savers reset the display.
Even other programs will reset things you had no idea.
Remember to read the information packet before loading apps.
Good luck these are the most common Tablet issues.
Apr 08, 2015 | Tablets & eReaders
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
My laptop wont turn on
I think your battery or your whole motherboard is fried. Does it make any noises? Do the fans start to run? Try unplugging your battery and only keeping your charger in.
Jun 02, 2013 | Acer TravelMate C300 14.1 XGA LCD Display...
My Averatec C3500 powers on all lights come on except the blue one, which i think is for the display. the screen dosent display anything, when i hook it up to an external monitor via vga it still dosent...
hi
i found the Averatec link for support -- i was able to locate something may help you -- but if you are not egtting any viewing, then the LCD panl;e may be defective or dmagaed somehow.
go to this link , .. it may be brightness issue (hopefully)
http://www.trigem.com/us/support/faq_view.asp
Jan 09, 2011 | Averatec C3500 Tablet PC
My Toshiba Portege R200-S2031 LCD display has developed lines across top and RH side of screen. What kind of fix is there?
First, give the screen a good cleaning using a microfiber cloth. This may inadvertently remove the lines even though they are in the display.
If this doesn't work, you'll have to send the laptop back for repairs. Screens are not a component that can be replaced easily (such as RAM or a hard drive).
If your laptop is not under warranty, scope out some local computer shops that can replace the display for you. Make sure to ask them for a quote BEFORE they do work on your computer, otherwise they have the right to deny you your laptop, once they fix it, until you pay up (a possibly very nasty price).
Mar 30, 2010 | Toshiba Portege R200-60 12.1 XGA LCD...
My pavilion 1410 starts up but screen is blank, all lights are on except wireless is amber not blue. I closed the lid before it shut off, I have charged it but still will not come on. Don't know if windows...
It appears this is a lemon laptop as i have heard of dozens of people with the same exact symptoms "including my family" . I think every one should get hp to fix them or they should have to repay the consumer. sounds like defective engineering and class action suit. I own 4 Dell laptops and 1 Dell desktop and they all work but the hp laptop and the hp desktop we have both failed shortly after warrantee expired.
Oct 23, 2009 | HP Pavilion tx1410us Tablet PC
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Stripes on Display, is there a way to repair?
If you have tried to reload the drivers and the same thing you still have stipes on the display... uuum i sugest change your screen.. normaly when LCD gets stripes no option but to change it.
cheers
Aug 27, 2008 | Fujitsu LifeBook T4210 Tablet PC
My display is not working well
Not displaying well?...change the resolution to highest setting in display properties!
Feb 12, 2008 | Toshiba Satellite R25-S3503 Tablet PC
Display problem in Toshiba Satellite pro L20
did you try the FN and F8 key and try that see if that turns the lcd on. If not write back here and we can figure it out.
Dec 18, 2007 | Toshiba Satellite R10-S802TD Tablet PC
ViewSonic TPCV1250S (TPCV1250S0103) Tablet PC Logo
120 people viewed this question
Top ViewSonic Tablets & eReaders Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
tosin_christ
Are you a ViewSonic Tablet and eReader Expert? Answer questions, earn points and help others
