Question about Garden
Lawnboy model 10360 lawnmower. only 1 rear wheel pulls, why? This problem makes it very difficult to use especially on a bank.
    Scholar:
  • 110 Answers
Probably a stripped gear or failed rachet component inside the 'lazy' wheel. Not difficult or edxpensive to repair.
Posted on Oct 06, 2009
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
Lawnboy silver series is not etting y spr
ask qustion again be specific is rear drive not working let me no
Aug 26, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
LAWNMOWER STRING WONT PULL
Unplug the spark plug.
Try to turn the blade by hand, be sure to use a heavy glove to protect your hand from the sharp edge.
If the blade turns, then move it back and forth to free it up.
If it won't turn, take the spark plug out and try to turn the blade .
If it won't turn, you may need the engine overhauled.
If it will turn, put a level teaspoon of light oil in the spark plug hole, and turn the blade a few times.
Now try the pull rope.
If it works, put a level teaspoon of fresh gasoline in the spark plug hole and install the spark plug.
It should start
Be blessed.
Feb 17, 2013 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
256 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
