Question about Kyocera CopyStar CS-3060 Black and White Copier
Error type: Connect?? Can't scan.
    Sniper:
  • 57 Answers
Check your ip settings.. or if your scanning to file, make sure you have the directory path correct and have the right authentication credentials if its on a server..
Posted on Oct 16, 2009
How do i fix ps3 error 8001000a
Go to network under settings, select wireless, hit scan, and click on whichever router is yours. type in the routers password as needed.
Aug 22, 2014 | Sony Playstation 3 (PS3) Console
Error type: connect
smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
Jul 09, 2014 | Kyocera FS-1128MFP FS-1128MFP...
Scanning Problem FS-1135MFP. Error Type: Connect
check to make sure all your smtp info is correct (server address,authentication ,and auth user and pass)
Jun 02, 2014 | Kyocera FS-1118MFP Laser Printer
Error type connect model 1128
The following is the list of info required to setup smb scanning. The easiest way to enter it, is via the devices webpage. Make sure the folder is fully shared.
"Host Name" = The computers name
"Port Number" = Either 139 for windows XP computers or 445 for windows 7 computer
"Path" = name of folder where the scanned documents are sent/saved.
"Login User Name" = Windows user name
"Login Password" = Windows login Password
Feb 24, 2014 | Kyocera Office Equipment & Supplies
I get this error: ERR_INTERNET_DISCONNECTED
Try to disable your antivirus and check if you would be able to connect to the inet. If it would work uninstall Anti virus and reinstall the program.
2. run a scan if possible to check for any malicous software.
3. reset winsock catalog by following the steps below.
Go to run.
type cmd
on the command box type in netsh winsock reset.
restart the computer.
Mar 16, 2011 | Google Chrome
Scan error - Can not connect
If you are scanning from your pc and seeing this error message it could mean that your scan drivers are disassociated. If you have multiple multi function printers or scanners that could be causing the problem as it creates a conflict with the software framework. I would recommend uninstalling the software as well as any other multifunction and reinstalling the software as well as the additional product software.
If you are scanning from the printer it may not be set up and you would have to set up scan destinations.
Al
Eliteprintersolutions@gmail.com
Jul 10, 2010 | HP LaserJet 3052 All-In-One Printer
I can not get my ps3 to connect wirelessly to the dsl-2640r router
You need to know what the error is first. Under Internet Connection Settings, make sure to choose Easy. Then scan for wireless network manually. If it found your network, highlight it and connect. Now it will asks you to type network key, that's the critical part. Make sure to enter the exact network key, it is case sensitive. If you can give us the exact error after connecting, we can give you the exact solution here. Try it first.
Oct 22, 2009 | Computers & Internet
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Internet connection error
Simple steps: 1. Push "up" the WLAN switch by the left side on your PSP 2. Go to "Internet Browser" 3. Go to "Address" 4 Type in your web address and pres "start" 5 When prompted with internet connection settings, choose new connection and Scan for Wireless access points. 7 Choose connection with no security and good signal strength, save your settings (Press "=>" all the way). 8. Select your newly made connection and there you go!
Aug 18, 2007 | Sony PlayStation Portable (PSP) Console
Kyocera CopyStar CS-3060 Black and White Copier Logo
1,907 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
