Question about Motorola Mobility RAZR V3
Razrv3 will not hold a charge
I have replaced the battery twice.and i only get 2 hrs talk time. what can be draining the battery
  • carol hall Dec 23, 2007
    i have already done all that from did not make a different
    Problem Solver:
  • 21 Answers
some time it is your blue tooth option, if its on it takes extra juice from battery, big file of ring tone also takes extra juice from the battery.
I have came across with bad battery twice. if you have spare phone, try same battery on ur spare phone. this with confirm the issue. if not request ur service provider to send you another battery, and please make sure it is OEM. also request them to see if they can send you Extended OEM battery, if your a good customer, they should send you at no additional cost.
hope this information help you.
Posted on Dec 23, 2007
Not hold charge for more than 3 hrs
the battery is fried, you will need to take it to a place that can replace it for you
Jun 02, 2014 | Apple iPod nano
My battery was charged the whole night but it can only used for half an hour is that means that the battery is already loose?
could be. oNe thing to try is let the battery die completely. Then try an overnight charge. If it still works the same, then the battery has bad cells and will need to be replaced. Good Luck.
Mar 23, 2011 | Acer Aspire One PC Notebook
My mobile phone charger broke and I couldn't charge it for two weeks. After ordering a similar model from China with the same charger, the phone still didn't want to charge and I can't turn it on.
replace the battery and see. when the battery is drained 100% and kept it drained for longer time period they never get charged after that but in ur case 2 weeks is too early for a battery to do that. Keep it connected for atleast 8 hrs and see , it does not work after 8 hrs then u sure need a new battery.
Aug 04, 2010 | Cell Phones
Dead battery after 24 hrs wont hold the charge! baterry is new
Find the battery drain. Disconnect negative cable from battery. Place test light between pattery negative post and disconnected negative cable. If light is bright while no accessories are on, there is a drain. While keeping the test light in this configuration, pull each fuse out and replace on at a time while watching test light. If the light dims or goes out when a particular fuse is out, that identifies which circuit has the drain. Use that information to track down what is on or draining.
Feb 21, 2010 | 2004 Pontiac Montana
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
Motorla Slvr L7 Won't hold charge
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Battery not staying charged
what kind of reception do you have in your area? If you don't have good reception it can really kill your battery. Is your bluetooth on all the time thats also a battery killer. Those a re the two i see the most in the shop. How much time do you talk on your phone? If you can get more than 2 hrs talk time the phone is actually doing pretty well. Mine straight out of the box only got about 16hrs on a charge. 6 - 8 hrs if i talked a lot!
Anyway there may not be much wrong. Just check your reception and see if your bluetooth is on all the time. Good Luck!
Jan 08, 2008 | Motorola Mobility RAZR V3
RZAR v3 battery issue
try using until the battery is dead, then recharge for 24 hrs. let me know if it working so we can do other method
Nov 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
