Question about Sennheiser RS130 Wireless Headset
Sennheiser TR140 sound from only one speaker - Sennheiser RS130 Wireless Headset
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
Why is there no sound even in bypass mode?
The bypass switch developes dry joints after some time. The earpad has to be removed and the speaker plate unscrewed and lifted back. The cct board connected to the switch will now be exposed so the switch legs can now be resoldered. Reassemble and you should be good to go.
Apr 28, 2014 | Sennheiser PXC 450 Headphones
Left speaker not working
I don't believe it to be a cable or plug problem, so it sounds like it's a speaker problem. I look up the review of these and it could have some kind of circuit built into each side. If it does it could be that. As they are not cheap headphones by the look of it, perhaps worth repairing. But if the speaker has gone, it might be as much as a new pair.
Jan 03, 2014 | Sennheiser HD 558 Headphones
Sennheiser OMX980 ear hooks
No, finding spares for Headphones is difficult since they are all different, it's not the same as cabinets or speakers. You are better off buying a new pair and keeping your old ones as a spare.
Jun 08, 2013 | Sennheiser Audio Players & Recorders
Sennheiser headphone static
you might check to make sure that your gain isnt to high many times this can negatively effect your sound quality
Mar 25, 2013 | Sennheiser Audio Players & Recorders
Sound in one ear
I had the same problem, and it is a very simple fix, the cable connection can fall out of the speaker piece on the right side.
I have made a blog post with the steps for removing the cover on the Sennheiser HD570.
Opening the HD570 for repair
Nov 17, 2012 | Sennheiser HD 570 Consumer Headphones
HD600 no sound in one ear
Go inside and test the speaker with a small low power battery, connect it quickly (just a quick touch) to the terminals of the speaker, it should pop! If it doesn't it's gone.
If the Sennheiser don't have replacements, then it's bin time!
Nov 12, 2009 | Sennheiser HD 600 Consumer Headphones
Sennheiser RS130 Wireless Headset Logo
505 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
