Question about Kodak ESP 5 Printer
Printer not working properly so i tried to uninstall software but it wont uninstall
My computer wont find my lexmark x5495
It could be due to the printer driver not installed properly. Try to uninstall your existing Lexmark printer driver first before installing the new driver. To do that, go to Start menu > Programs > Lexmark X5400 Series Printer > Tools > Uninstall. After the uninstall process, restart your pc when prompted.
To re-install the printer driver, please visit the Lexmark website to download and install the Lexmark X5495 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Then try to print a document to verify that the printer driver is properly installed.
Feb 09, 2012 | Lexmark X5495 Printer
My new lexmark 1200 is connected to my pc and electric the ink cartridges are in correctly but it will not print paper runs through fine but comes out blank
Make sure that the printer is properly installed on your computer that's teh first thing you need to do, if its installed properly try to do a test print using the printer utility and see if it will work..
You can also turn the power and turn it back on and try tp do a test print agin ...dont forget to check the connection
Hope that helps......
Aug 05, 2008 | Computers & Internet
My computer doesn't recognize my printer even several attempt of software installation is performed.
Before you made several attempts to install you Epson Printer Software.Did you Uninstall the software first? To reinstall your Printer Software . The old program that did not work properly has to be uninstalled. Go to your Add and Remove Programs In your Contol Panel and uninstall your Epson Printer Program Software .Then restart your computer.Then try Re-installing your Epson Printer Software.
Jul 30, 2010 | Epson Office Equipment & Supplies
Z2420 Printer: We installed the printer then we uninstalled it so...
Most probably the software was not properly uninstalled. Check this link to the Lexmark website on how to properly uninstall the Lexmark software. http://bit.ly/aQZEqZ. Follow the instructions carefully. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 16, 2010 | Lexmark Z2420 Printer
Scanner won't stay installed
When you install the printer software is it installed properly? if the printer is installed properly then you will do need to do the same step. First, uninstall the printer software by going to control panel > add/remove programs and then uninstall all the printer software. then go to control panel > printer and faxes if printer is present in the printer and faxes delete the printer. Restart the computer. Before reinstalling the printer software turn off your firewall, anti-virus, spyware if you have any. Then reinstall the printer. Try to scan again. if it works then try to restart your computer and scan again. it should work
Oct 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
Epsom R340 wont work with vista
uninstall the printer software for the Vista, and install the XP software.
Jan 20, 2009 | Epson Stylus Photo R340 InkJet Printer
Uninstall hp psc 1310!
If your trying to uninstall the printer because it fails to print and you want to reinstall it. Then try this.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | HP PSC 1610 All-In-One InkJet Printer
If your trying to uninstall the printer because it will not print, try this and it should work.
"Printer not responding" message when printing test page
Have you tried deleting and re-installing the driver? And what kind of machine are we speaking of?
Larry
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Kodak ESP 5 Printer Logo
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
