Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Small part fell out in grass and I can't find it. Where can I fi
The 0.08 nylon string comes out through a 1/2" metal grommet. There is one on each side of the spinner. It is only held in by friction. One of them fell out while I was trying to add more string. It fell in the grass and it is aluminum so I can't find it using a magnet. Chere can I buy a replacement. The unit is worthless without it and a totally new head is $25.
Don
donmathis37@gmail.com
  • 143 Answers
They are called strimmer eyelets and most hardware shops, repair shops or hire shops will sell them
Posted on Oct 07, 2009
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
How do you get the string to come out of the spool whilst the snipper is in use ?
There are two or more types,
1: provided the spool is full and wound on correctly, to increase the length of nylon you tap the head of the snipper on the ground while it's spinning. This should release extra cutting string.
2: others are simply feed by the centrifugal force governed by a spring in the head. When you wrap the nylon string around the spool, then feed the nylon out the holes provided, the weight of the nylon string pulls the required amount of nylon out so you can continue to work.
Others are manual, simply pull the nylon out by hand to the desired length.
Note that you are only cutting with the very tip of the nylon string, not the full length.
Mar 29, 2015 | Garden
You are trying to get a value of an instrument via in fixya with no pictures and very little detail? Go to a instrument store or at least a pawn store!
Jun 05, 2014 | Music
Trimmer wrapped around shaft
Deborah there should be a little hole just towards the bottom of the spool head where you could fit a small metal rod in. If you can locate it push something small in like a 2 inch nail and turn the spool head slowly by hand until it locks up. The head should then undo . It will undo anti clockwise.
May 14, 2014 | Black and Decker USA black & decker grass...
Putting on another spool, do I thread the line through the hole in the side?
I feel that the END of your trimmer line should exit THROUGH the hole in the side. That hole should have a small metal grommet to alleviate wear on the plastic head unit as the string flies.
So string your line onto the spool and when you are done, run the END of the line through the hole in the side.
Jul 04, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
STRING KEEPS BREAKING ON A TROY BILT WEED EATER TB539E
Take a look at the hole in the spool where the business end of the string comes through. There should be a smooth metal grommet or smooth short tube there. If the metal is missing, then the string is breaking because it rubs against plastic and heats up very quickly. Or the tube or grommet might have a rough or sharp spot. You might be able to polish it up with a Dremmel type of tool.
Sep 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
String breaks in a few seconds. Change spool no help. New 0.80 green string no help. What else?
The hole where the line comes through the plastic spool should have a metal grommet in it. If the hole is just plastic, then the line rubs against it and the heat cannot dissipate, so the line gets hot and melts.
Aug 13, 2010 | Black & Decker Garden
I have a Micky Mouse of a Black and Decker grass strimmer. The line breaks every time I use it for more than 10 seconds, the string is wound in the right direction and threaded through the hole in the...
Sounds like you may have lost the little metal grommet that should surround the hole that the business end of the string comes through. This grommet is usually aluminum because it is a very good heat conductor. What happens is that the string rubs very hard against the edge of this hole, which heats up the string in that one little spot enough to melt it. If the hole is only plastic, it cannot dissipate this heat. The grommet dissipates that heat and the string doesn't melt. I don't know if you can buy a replacement grommet. You might be able to a generic grommet like the kind sold for tarps. Or you can replace the whole part that should have the grommet in it.
May 25, 2010 | Black & Decker String Trimmer Cordless 12"...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
85 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
