Question about Esker VSI-FAX
Error sending fax envelope: empty input stream
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
How do i send my application forms if they are on paper?
put in an envelope and put a postage stamp and address on the outside of the envelope and then put it in a post office mail box that collects mail to be posted.
If you were referring to email you need to scan the documents and save them to a file. Then you to email and compose an email message and click on the attach a file option and attach eack scanned page via its file name.
If you do not own a scanner
if the place you are sending the application forms has a fax then find out the fax number and then send each page via fax.
If you do not have a fax machine check with your local newsagency if they have a fax machine that you can send faxes on for a paid price.
Jan 30, 2015 | Health & Beauty
FAX RX IN MEMORY AND FAX TONER EMPTY ERRORS AND I CANT RECEIVE MY FAXES BUT I CAN SEND IT...PLZ HELP
It sounds like your toner has ran out, so you cant print any more faxes out, the memory saving the unprinted faxes has filled up and cant save any more messages.
Replace the toner and let the machine print out the saved faxes. You should then be back to normal
Sep 04, 2010 | Sharp AM-400 Digital Multifunction Printer
Will canon mp530 stop fax mode if low on ink?
It will run as long as the ink is just low, when empty it will not let you proceed. It will take an incoming fax and hold it in memory until the inks are replaced. When empty the error will stop you from sending a fax.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Result Code: 85 - Hardware Passes But Com Port Is Not Accessible \r\n I am attempting to download/stream a content larger than 400kbps. as of 2 weeks ago I could do that. But now I seem to be able to...
Error Code 85System error code 85 means "The local device name is already in use." This error code may also display as "ERROR_ALREADY_ASSIGNED" or as the value 0x55.
May 21, 2009 | Dell Dimension 9100 PC Desktop
Error
You should be able to send out a fax on there without replacing the cartridge.
Jul 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Computers & Internet Logo
47 people viewed this question
Top Esker Computers & Internet Experts
David Payne
David Payne
Are you an Esker Computer and Internet Expert? Answer questions, earn points and help others
