Question about Garmin (010-00583-00) for nuvi 750/760/770
Nuvi 750 wont turn on even when i hold the on button for a minute or more
    Problem Solver:
  • 10 Answers
Looks like the in-built rechargable battery is fully discharged. Try charging it for good amount of time like more than an hour through Car or computer charger. Keep the unit off to maximize charging.
Posted on Nov 06, 2009
Garmin wont let me enter address
) Turn the Nuvi off.
2) Put one finger on the screen and hold it there through the next couple of steps.
3) Turn the Nuvi on with the slider and immediately put it into the lock position.
4) Keep holding that finger on the screen for about 20 seconds or so.
Sep 25, 2011 | Garmin n?vi 750 Car GPS Receiver
Wont turn on
How do you turn it on ? Power button needs be pushed left to turn on, right is locking device.
If this does not work, check charging the device. Plug it in charger for 4 hours.
If all this is OK, you should reset device
Hold power button on left for 8 seconds. Release, then restart normally.
Sep 26, 2010 | Garmin nuvi 750 GPS Receiver
Nuvi 750 will not turn on
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Apr 14, 2010 | Garmin nuvi 750 GPS Receiver
My garmin nuvi is only giving me distance and turning directions. Has suddenly quit giving me upcoming street names.
Try restoring settings by going to tools, settings and restoring Map, Display and Navigation choices. If does not work after these procedures try a full reset by switching off by holding button over 8 secs.
Oct 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin nuvi 750. Was working now it will not turn on
Hello there:
you need to first make sure the fuse in the power cord is not blown,
next check to see that all connectons are tight and if the battery can be removed make sure that all of the contacts are in good working order and are clean,and makes a good connecton with the unit.
when you power up the unit hold the reset in for 2 minutes and then release this should reset the whole system.ok if this doesent help i would consider contacting a local authorized dealer to see if they can test it for you ok?
best regards michael
Aug 24, 2009 | Garmin nuvi 750 GPS Receiver
Garmin Nuvi 750 will not turn on. Any ideas on
Hi Jessica,
Move the on/off power switch to the left and hold it there for at least 30 seconds and see if it comes back on. I know there was a bug in a firmware version that makes the unit "bricked" after a certain date. The only way to fix it if the reset didn't fix it is to disconnect the battery inside, reboot the unit and install the firmware fix.
- Jim
www.sharcnet-usa.com
Aug 06, 2009 | Garmin nuvi 750 GPS Receiver
My 750 won't turn on. Is there a reset on it?
Hold the on/off button to the left for 10 sec. If this does not work turn it on and press the bottom right hand corner of the screen this will put it in reset mode but be careful as it will wipe anything you have stored on your machine.
Jul 11, 2009 | Garmin nuvi 750 GPS Receiver
Can't get to bluetooth setting on my garmin nuvi 750
The Nuvi 750 does not have Bluetooth capabilities. Simply put, there is no way to connect your phone with the Nuvi 750 via Bluetooth.
Dec 31, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin (010-00583-00) for nuvi 750/760/770 Logo
452 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
