Question about Datamax I-4208 Thermal Label Printer
Diagraph software says printer is off line and i dont get a print out EZlabel software prints out ok
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
White line goes across printed words horizontally
this sounds like the printer needs re-aligned. this should be a setting in your printer software. if you dont have printer software but have just the drivers to make the printer function, then it will be in the printer properties. if you re-align your printer, these white lines between 1 inchs should dissapear. SHOULD. our lexmark printer here has this problem as well, but i dont pay it any attention. as long as it prints im okies with it
Jun 03, 2010 | Canon PIXMA MP780 All-In-One InkJet...
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Printer printing blured images and text. It looks as if the printer prints a line then about 1/8 to 1/16 if an inch it prints the same line again.
You need to run a new alignment on the machine, Assuming you have the software installed open up the hp help center and print an alignment page after that look at the numbers and letters and line up the marks by selecting the numbers closet to the perfect alignment that you can see after you have finished click on the front of the printers OK button.to finish they try printing a new page. If this does not help try updating your software at http://www.hp.com.
Dec 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
Stripey printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 28, 2009 | Canon BubbleJet i560 InkJet Printer
Laserjet 1020 with mac osx
Ok, you may want to consider re-installing the printer driver or in any case download updated printer drivers. Just don't forget to reboot after installing:)
Oct 16, 2008 | HP LaserJet 1020 Printer
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
PRINTING LINES
remove the cartridges and the printhead
do a deep clean by pressing menu>clean printhead
see if it will make a difference then also check your ink levels..
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Datamax I-4208 Thermal Label Printer Logo
23 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
