Question about Intermec PB50 Thermal Printer
Intermec PB50 prints excess labels during start up
  • 18 Answers
SOURCE: Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Posted on Sep 06, 2007
Dyes
  • 6 Answers
SOURCE: Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Posted on Aug 15, 2008
RCtech
  • 55 Answers
SOURCE: I have an Intermec PF8t
depending on what version of office your using you will find a label tab under mailings (in office 07) or under tools (previous versions) you should be able to specifiy a label type or build a custom label.
Posted on Dec 10, 2008
  • 148 Answers
SOURCE: Printing Bar Code Labels from Intermec 3400
here is the specific intermec syntax (stx(esc)E1(can)(data)(cr)(data)(cr)(etb)(etx)PRINT
You have to send this sequence with no spaces (use hex equivalent or control c etc)
You can call intermec product support or call Scan Source tech support and they will hep you
Best of Luck
Posted on Jan 04, 2009
  • 148 Answers
SOURCE: I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
Intermec printer prints slow
The print speed is surely the bottleneck. I did find this:
http://apps.intermec.com/downloads/eps_man/937-028-003/Content/Print_Speed_Set.htm
Page 65 of the manual discusses adjusting the print speed, for "fingerprint" not IPL. (I'm not sure what that refers to, but it appears to be the language used by the printer.)
Jan 20, 2018 | Intermec EasyCoder PM4i Thermal Barcode...
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Sep 06, 2007 | Intermec EasyCoder 3400 Thermal Label...
Intermec PB50 Thermal Printer Logo
90 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
