Question about HP PSC 2110 Color Printer
Printer The printer prints up the alignment paper then I put it on the printer to scan then it scans then it finds an error of no alignment paper on the scan glass so I repeat this again and again
  • almb Dec 23, 2007
    I did very thing and it still don't work and at one point I thought it was going to work but it started all over again and I even turned it off and tried it again and it still don't work. I know that you were only trying to help!!
    Thanks, almb
    Scholar:
  • 54 Answers
This issue occurs if the alignment page is not perfectly or with good colors. Replace the low ink cartridge. If the ink levels are good do the following steps to clean cartridges :
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
area of the cartridge should be rubbed briskly to remove the waxy
lubricant material from the gold contacts.
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Steps to manually align cartridges
1. Press Setup until Maintenance appears, and then press Enter.
2. Press until Align Cartridge appears, and then press Enter. Two pages are printed, one with instructions and one with patterns.
3. Follow the instructions on the instruction page, then place the page with patterns on the glass and press Enter. The cartridges are aligned correctly.
If the issue persists do the below to by pass alignment :
Press Setup and Options (or Copy Options) simultaneously when align message is prompted on the All-in-One.
Thanks
Posted on Dec 22, 2007
  • Chandrasekhar Beura
    Chandrasekhar Beura Dec 23, 2007
    MAY I KNOW HOW IT IS NOT APPROPRIATE ? THIS MAKES US UPSET. PLEASE EXPLAIN.
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Every time i open the printer an alignment page is printed.How can i disable that??
it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Feb 16, 2010 | HP Inkjet 1200dn Printer
Keeps wanting to print alignment page
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 20, 2009 | Lexmark X2470 All-In-One InkJet Printer
Changed black cartridge. Machine works fine, but
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Alignment of cartridges
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Place align paper on scanner glass
1,Unplug the USB cable
2,Place the allignment paper in the right bottom corner of the scanner glass
3,close the lid
4,Press the Start scan button
You will find the light blinking wait until it completes.
Then connect the cable and the issue will be resolved.
Hope works well for you
Apr 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Printing alignment is cross
You can rerun the printer alignment to see if that is the issue.
Push the setup button and then go down to Tools. Press ok and go to align cartridges and press ok. When the alignment page prints be sure to put it down on the scanner glass and press the scan button to finish it.
Oct 25, 2007 | HP OfficeJet 6310 All-in-One Printer...
How do you align your printer
WTF...wheres the solution. Bunch a ****!
Oct 14, 2007 | Lexmark X2470 All-In-One InkJet Printer
HP PSC 2110 Color Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
