Question about Fuji FinePix A700 Digital Camera
It reads memory full
And yet it is not - I have a H256MB picture card in it and I don't know how to ensure the camera is set to use this rather than the maximum of 6 pictures it holds on the camera memory
Whenever i take a one picture with my camera it will say memory full after i take one picture.
Hi! Some cameras have a limited internal memory. To make more space on your camera, you need to connect it to a computer to move the pictures in there, or to add a external memory space to your device like a memory card. However, you should know that memory cards have different sizes and you need to check your camera to see what type of memory card accepts.
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 04, 2011 | Cobra Digital DC6550 Digital Camera
Don't know how to set up my camera to take pictues
turn the camera on with the button on top, then take off the lens cap and insert a memory card into the side. The pictures will save to the memory card and you can buy an adapter to connect the memory card to your computer to view and save the pictures.
Jul 03, 2011 | Casio QV-R40 Digital Camera
I have an Olympus C-740 Ultra Zoom Digital Camera. I bought a new memory Card. This camera is new to me and this is the first memory card I have purchased. I do not have a manual for the camera. I am...
Choose YES for the Format option. Allow it to finish. Should work fine then.
Possible defective card if does not work after full format. Do not use any "quick format" option.
First time must be FULL format.
Nov 12, 2010 | Cameras
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
I can only take 5 pictures with this camera before it says that the card is full. i have already changed the card twice is there something wrong with the camera or the card
This sounds like a problem with the memory card.
Your camera has 19MB of internal memory (used to take test photos in the shop usually) which is what the camera is using here.
You may need to format the memory card before use, assuming it is inserted into the camera correctly.
I have linked to the camera's instructions (PDF Format). Follow the details on page 30 describing how to format your memory card. Please also read through the set up at the beginning to ensure the card is inserted correctly. Thanks
Dec 24, 2009 | Olympus FE-46 Digital Camera
I uploaded my pictures from my memory card onto the computer. When I put the card back into my camera, the camera won't read the memory card and it says the internal memory is full (12 pictures). How do...
If you indeed have the pictures on your computer (and are safely stored)... you might try selecting the format memory card function in the camera, to reformat the card, in case it was somehow corrupted while connected to the computer.
Aug 09, 2009 | Kodak EasyShare M853 Digital Camera
My camera will not read a memory card
Send the camera back to Kodak. Go to Kodak website for warranty info and address location of warranty centers in your area.
Jul 03, 2009 | Kodak EasyShare C913 Digital Camera
Internal Memory is full??
If you dont put a memory card in your camera it is forced to record on and read from the internal memory (which is pretty small). If you do insert a memory card (is it a memory stick?) you can read the card but not the internal memory. Try it both with and without the memory stick.
Apr 29, 2009 | Cameras
Does not want to take pictures
Have you checked whether the memory card is full?
Oct 22, 2017 | Sony Cyber-shot DSC-M2 Digital Camera
Finepix s700
I had the same problem. Once it said "Memory Full" there's no way to get rid of it how much you try to recover, format the card, reset the camera with no avail. I had thought the camera was out of order. Then googled around and come across with this workaround. When nothing else works for you just take out the memory card. Take a picture to the internal memory of the camera and then insert the card. Voila!! you can enjoy our camera. I guess this is a software bug. The camera can not reset the memory card full flag before you take a picture to the internal memory.
I hope this helps.
Mar 20, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix A700 Digital Camera Logo
29 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
