Question about Cuisinart TOB-30 Classic 1500 Watts Toaster Oven with Convection Cooking
My Cuisinart TOB-30 beeps occasionally. Why? Have had it about 5 yearsand haven't heard it before. The Instruction manual doesn't have anything about beeps. Joe Parks
  • Frank Leon Rose
    Frank Leon Rose Apr 30, 2015
    Mine too. Spontaneous long beep followed by 1 short beep then long beep again followed by 5 short. I figured it was trying to report an Error Code 15, but couldn't find any reference to self diagnostics on these toasters.
5 Suggested Answers
  • 30 Answers
SOURCE: CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Posted on Dec 30, 2008
SOURCE: Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Posted on Mar 14, 2010
SOURCE: cuisinart tob-30bw,is not starting ?
The problem is 4 capacitors on the small circuit boards inside. Three 220uf 16V and one 1uf 50v. These apprear to be going bad from internal heat drying them out and they fail. Symptoms include toast will not start when button pressed, or does start but then stops soon after. A buzz or hum heard when the Toast selection is made..(you should hear nothing until the start button is pressed) and the timer beeper no longer working. These are about $2 in parts, and easy for a good electronics person.
Posted on Mar 02, 2011
greg_margo
  • 1959 Answers
SOURCE: Why does Cuisinart TOB-40 produce steam and
The bake/toast compartment is almost air-tight, creating an adequate seal to produce steam/moisture when the heat is applied to the water content of the food placed inside.
Posted on Mar 23, 2011
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Leg on left side (facing oven) broke in half and will not accept glue repair
Same thing jus happened to me tonight. Already had the thing repaired because it wouldn't turn on. Booo Cuisinart!
Apr 11, 2011 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart tob-30bw,is not starting ?when i try to toast its not working
May 06, 2010 | Cuisinart TOB-30 Toaster Oven with...
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-30 Classic 1500 Watts Toaster Oven with Convection Cooking Logo
228 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
