Question about StarTech.com StarView SV211K 2-port KVM Switch
We accidentally deleted our channels and tried to scan them again but doesn't work we can get into parental control and putting our box code in were it says new and old code but we cant get further please help
Go back to installation and just click on automatic
Posted on Oct 07, 2009
I TRYED TO PLAY DVD IS SAID BLOCKED BY FAMILY SETTING, BUT I DON'T HAVE CODE
1. Place a DVD that prompts you for your password in your PS2. If you have any R rated DVDs sitting around, one of those should work just fine. It should prompt you for the password before anything else comes up.
2. Select "Yes" to playing the movie and select "Yes" again to temporarily suspend parental controls. This is where you would put in the password if you knew it and the DVD would play. You may try "1111" at this point, as it is often the password. If that doesn't work, continue through the next few steps.
3. Press the "Select" button on the screen that wants you to input the password. This should change the text on the screen from "Enter Password" to "Delete Password."
4. Input the numbers "7444" into the box on the screen. This is the universal password needed to delete the current password. Once you input the numbers, you should get a message that says "Deletion Complete." Press the "Select" button again and you should be prompted to enter a new password.
5. Enter a new password for your parental control. Make sure it is something easy that you will remember. Once you enter it in, you will be asked to confirm your new password. Enter it one more time and you should be able to watch any DVD you want.
Aug 12, 2011 | Sony PlayStation 2 (PS2) Console
LTA260 digital converter box. My nephew played with it asnd entered a pass code in the parental control. Doesn't know the number. I'm locked out of most channels. How can I clear the code?
U can't in most cases,that why they called a secret passwords codes.U only can tries this by unplug the converter box and replug it back 24 hours later.Go to parental control codes mode and resetting the mode,might resetting the mode and erase the secret passwords codes,only some models of boxes could do this,ur included don't know sorry.
Aug 06, 2011 | Televison & Video
I have a receiver and accidentally locked one channel. Problem is i do not know how to unlock the parental lock. what is the usual default lock code for parental lock?
If you have not set a code for it, most parental lock default codes are simply 0000. If more than a 4 digit code, just put all zeros.
Aug 24, 2010 | Televison & Video
I would like to delete some inappropriate channels on my freeview. i have tried to put parental control on, but it hasnt worked!
It sounds to me like you need to block the channels on the converter box for freeview. The television parental control will only work if you are using basic cable hooked directly into your tv. Otherwise, all of the channel control functions are handled by the control/converter box from your service provider. If you do have cable hooked directly into your set, try consulting the owners manual either online or the copy provided with the television. Good luck, Russmann.
Aug 16, 2010 | Samsung LE32A41B 32 in. HD-Ready LCD...
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Problem with Starview The Box 4.54
Problem solved, box had been accidentally factory defaulted, was as simple as rescanning channels and exiting out again at which point both "parental lock" and "channel edit" were accessible.
Jun 12, 2009 | StarTech.com StarView SV211K 2-port KVM...
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Remote doesn't work
I have lose my remote and I have parental code lock n Iam using my cable remote, but can not key my code n cable remote to deleted parental off.Please help me
Feb 07, 2009 | Orion STV2763 27" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
