Question about Toshiba 57H81 57" Rear Projection Television
Distorted Picture Upon Startup
When the TV is first turned on the picture is distorted and shakes (like a TV with poor reception). However, as the unit warms up the picture quality becomes more stable and clearer after apx. 5 min. and is back to normal until shut down and cooled off. The convergence IC’s adjustment’s respond to automatic and manual adjustments, so, I kind of feel the IC’s are not the problem (but, I’m not the expert). I did remove the printed circuit board to inspect for possible cracked solder area's but failed to locate any. The fact that the system performs great after a 5-min. warm-up is what bewilders me.
Any help is greatly needed and I thank you for your time!
Have a great Holiday!
  • drinfl Dec 23, 2007
    Troylove11,
    Thank you for your prompt response. Is the capacitor part of the power supply and replaced as a unit or serviceable alone? Are there wiring breakdown data available online?
    Thanks again, have a safe holiday!
    Genius:
  • 1,153 Answers
You have a bad capacitor in your power supply.
Posted on Dec 23, 2007
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
The picture is distorted by both vertical and horizontal lines (different colors; pixelated)
A distorted picture display soon after the Plasma TV is powered on has two indications. First, a picture display of pixels when the TV is powered on is usual prior to signals of video movies are acquired from broadcasting station. The movie from braodcasting station should display without noticeable objects of distractions. For example, the movie displeyed on the TV without obstructions is indication that the problem is from the display set. Alternately, movies with poor capability to display on the set is indication that the media from which motion pictures are acquire from is malfucntioning. For example, a TV connected to cable network or disk network or satellite broadcasted signals with receptive compromises are diagnosable from two areas. First, a clarification from the network station that has setup connectivity of devices. Perhaps a device in the setup is malfucntioning. Second, attempting the adjust the phsical connections that are attached to the TV is capable of resoving the problem. Refer to the user guide for what is default expectation on powering on. Thereafter consul technical experts if required. Good luck
Jan 08, 2011 | Philips 42PF9630A 42 in. Plasma Television
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Can't see picture
Is the onscreen menu just as distorted and are the lines across it or behind it? The pop you heard may have been a capacitor and since the TV is still powering on, it's the probably the video controller board that is on it's way out. If the onscreen menu looks fine, you maybe having a problem with the input board only so try a DVD that uses a different input and if it's poor, I would say the TV needs to have the input/output board service. If the OSD is distorted as well then it's definitely the video controller board and service is likely required.
Oct 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Tired with this sony tv
Sony doesn't want anyone to see a poor picture on a Sony tv so they have a circuit that blanks the video if there is a weak picture or any other problem concerning picture quality. My Sony factory Instructor told me this many many years ago. I'm feeling old...but anyway you need a technician. Sorry.
barneyluc
Oct 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 57HX81 57 in. Rear Projection
Im guessing the the convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Toshiba 57H81 57" Rear Projection...
Video for the Xbox become very distorted
Try putting the XBOX on another TV and see if still happens. If it does then you may a have a problem with your XBOX360 on board video and may to send in to Microsoft.
Dec 08, 2007 | Microsoft Xbox 360 Console
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
