Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence Problem The picture had a red and green outline hurts my eyes, tried the manual convergence with the TV remote didnt allow me to adjust it all the way, there is still outline
  • 647 Answers
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Oct 05, 2009
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Magic focus runs half way & stops &showes a #4 ? one side of a face has a green outline the other side red
You may have a burned out convergence chip. But first, if you haven't already, you can try service mode to adjust convergence. Press the Magic Focusbutton, and then press it again to stop it, and then press the Statusbutton on your remote. Here's a link to the manual convergence procedure (scroll down). Warning-- When I did this the set got stuck in one of the adjustment screens. I had to remove the bottom front panel of the TV to reach the "little blue" reset button to get back a TV picture. But I think this is worth trying before replacing parts.
Mar 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
My convergence is fine but after professional replacement of the board there is a slight bowing and slanting of in-screen borders and some channels have a little distortion at the top of the screen. The...
First: If the convergence board was replaced--the set may need a total adjustment---this is why most good techs replace the convergence chips and any bad parts instead--also costs less----Second: to enter the service mode (it is done with the set already turned on) should be Mute, 182 or Mute 183---if you get the convergence mode--7,8, 9 will select red, green, blue, 5 will stop the cursor from blinking and allow adjustment---with the cursor blinking 2,8, 4, 6 will allow you to navigate---depending on the remote used--the P mode button will take you across the screen in a series of steps--the remote I use for this has a button on it marked data save--this saves the adjustments. Your remote may have it or a different button for this.
Understand---if you get into the convergence mode---Green determines if the geometry of the picture is straight---red and blue are adjusted to it---to align the green you need to call the convergence mode up and then cover the lens for the red and blue---leaves you with a green grid---then you need to select green and wherever the grid is not straight adjust it--once you get it straight you need to uncover the red and adjust it to the green, and then the blue to the green---green alignment determines if the picture is straight---It sounds like this guy did not try to get the green straight and just adjusted the red and blue to whatever the green was.
My point here is if you paid money for this repair--either he aligns it straight or you should get your money back----GREEN never needs to be adjusted unless the dcu(digital convergence unit that stores the adjustments) has been replaced or the Convergence module has been replaced---I bet if the original convergence module was repaired(chips replaced etc) and installed you would not have this problem.
If the guy replaced the DCU then GREEN must be fully adjusted for a straight picture FIRST! then red and blue adjusted to it.
It is not easy or quick to Adjust the green--maybe he just wanted to get out the door?
I do this here for free so if this has helped you take a minute and give me a vote here.
If you have any questions or need help reply to this post here.
SD TECH
Sep 05, 2009 | Samsung PCL6215R 62" Rear Projection...
Green and red lines
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 19, 2009 | Sony KP-57HW40 57" Rear Projection...
Convergence controls
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 20, 2008 | Philips 51PP9100D 51 in. Television
52 in rca projection 2006 cutting of the top of heads of people
There are manual settings on most projection tv's to adjust the size and to bring the picture down so it is centered on the screen better. Try adjusting the three colors mentioned below first. All projection tv's are pretty similar. If you need to adjust the picture manually, which you should not have to, there are manual knobs behind the front of the tv or at the rear. They should be marked for thier function.
Here is how to adjust the convergence one color at a time.You should be able to get to the convergence screen with your remote. You need to go into the setup screen and read what is on the menu there. It should say how to adjust when you get there.
Convergence- The Auto convergence feature automatically adjusts the TV’s tubes
(this may take several minutes, after which you can make fine adjustments to the
convergence settings); Red convergence displays the Red convergence screen,
allowing you to use the arrow buttons to align the red and green images; Blue
convergence displays the Blue convergence screen, allowing you to use the arrow
buttons to align the blue and green images.
Also this is in the manual for a generic projection tv.
Call 1-877-RCA-HDTV and have your unit’s date of purchase and model/serial number ready.
• A representative will troubleshoot your problem over the phone.
• If the representative determines that you should receive service, they will provide you with the name(s) of the
Authorized Service Center in your area.
• Contact the Service Center and arrange for home or pick up, repair, and return service, provided that your unit is
located within the geographic territory covered by an Authorized Service Center. If not, you must take your unit to the
Service Center location at your own expense, or pay for the cost the Service Center may charge to transport your unit to
and from your home.
• Proof of purchase in the form of a bill of sale or receipted invoice which is evidence that the product is within the
warranty period must be presented to obtain warranty service. For rental fi rms, proof of fi rst rental is also required
Here is a link to rca tv manuals if you don't have one.
You can download them in pdf.
If this is not a help, please give the specific model number.
Apr 21, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
