Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Cold water reservoir replacement
I need to replace the cold water reservoir in the back of my fridge, is this something that is easy to do? Are there any online manuals/instructions you can point me to?
  • 1,543 Answers
Easy to do if you have a couple insta-push fittings. You need two 5/16 OD ones (just like the one behind the grill where the water line from the freezer door hinge connects to the water line comming from your refrigerator.) The 5/16 OD size is not very common (you may not be able to find them at many hardware or plumbing shops) but you can order two ( part number WR02X11330) when you order the new water tank.
Now, you will just use a sharp knife to cut the inlet and outlet tubes to the old tank, remove it, replace with the new tank, and push the ends of the tubes into the insta-push fittings and you are done.
On a difficulty scale of 1 - 10, I'd rate this one about a 2. Go for it!
Posted on Oct 05, 2009
  • edli88888 Sep 17, 2010
    I replaced the cold water tank in my GE fridge, but the plastic tubes into and out of the tank LEAK WATER at the blue plastic quick disconnects - one at the water control valve and the other at the tube quick disconnector under the freezer door. What did I do wrong? I pulled out the white plastic collar, removed the old tubes (had to use pliers to pull them out), inserted the new tube, took it back out (to see how deep it went in), put it back in, and moved the white plastic collars into the blue connector. BOTH TUBES LEAK!
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 20, 2010
    Some insta push fittings have a colored locking ring which must be removed so you can push the collar in, releasing it's hold on the tubing. If you just pulled the tube out, (without pushing the collar in toward the center of the fitting at the same time) you may have wrecked the fitting.
  • 4,070 Answers
If you can see the two connectors where the reservoir connects to the water line and get to them it won't be hard. Most manufacturers suggest using a coil of water line instead of the original because of flaking problems.
I have a samsung SRS619DHSS Fridge/freezer. The freezer is working just fine but the fridge is keeping cold. I was told by another expert that the fan bearing needs looking at. My question is where in...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 25, 2011 | Samsung Refrigerators
My freezer is working fine but the lower fridge is not getting cold. Recently moved it was'nt sure if i bumped something. Thanks Liam
EASY JOB.
Leo Ponder
imufo2
Sep 24, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
It appears the fan is not working (I think) inside the fridge - the freezer is working, but the frig is not cold ... any ideas ? Everything appears to be fine everywhere, but the fridge is just not...
EASY JOB.
Leo Ponder
imufo2
Sep 18, 2011 | Maytag Refrigerators
Whirlpool side by side fridge freezer, fridge compartment not working. control is fully open to allow cool air into fridge compartment. freezer is working normally.
EASY JOB.
Leo Ponder
imufo2
Sep 16, 2011 | Refrigerators
After an extended period of non-use, i attempted to start using my fridge again only to have the fridge section not get cold. the freezer section works fine, but fridge will not get cold. what do you...
EASY JOB.
If
you need more help go here:
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Water smelly bad taste. Sat for two months during kitchen remodel. Filter has been changed, and water flushed and ice cube ran several times. Can plastci lines be replaced? thanks.
When the fridge was turned off during that time ,the water left over inside the reservoir(plastic container inside the refrigerator side where the water keeps cycling and staying cold) might gone bad and contaminated the reservoir,in this case the reservoir needs to be replaced.But first try replacing the water supply line , if it's copper or a gray plastic pipe ,also could give bad taste to water.
Oct 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water showing mold like substance visible despite 2 new filters
Disconnect the water from the refrig. Get large bowl and turn on water supply. Does water look clear?? Flush real well.
Nov 23, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore refrigerator making spraying noise
Beth, sounds like your water reservoir in your fridge section has cracked. To get to it, remove the lower bins and shelves. You'll see it mounted on the back wall. After you see it, test by filling a cup of water from the dispenser on the freezer and watch the reservoir for the leak. To replace it, you'll need to contact your local appliance parts store and provide them with the complete model number (located on a sticker inside your fridge). It'll start with 3 digits then a decimal point then more digits (xxx.xxxxxxxx). Most reservoir replacement kits come with instructions and all the hardware you'll need. Hope this helps!
Sep 26, 2007 | Refrigerators
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
