Question about Fossil AM 3688 Wrist Watch
Watch band How can I remove a link from my watch band to fit my wrist?
  • 1 more comment
  • freeto Dec 25, 2007
    I am trying to find out if it is possible to remove links from a fossil BLUE watch band.It is a stainless steel linked band.The only number I see on the band is 112800. Thankyou
  • Anonymous Jan 01, 2008
    hjt
  • Anonymous Jan 18, 2009
    yeah how can you
    New Friend:
  • 47 Answers
You can buy anywhere because branded watches will not get any problem in branded watches. Do you know here get the best offer in your watches, Discounted Watches247
Posted on Mar 30, 2015
Why is this rated the best solution? there is no solution at all. are you kidding me?
Posted on Jan 26, 2008
How can I remove a link from my watch band to fiit my wrist?
Posted on Dec 26, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
SOURCE: tessot steel wrist watch band
i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
Posted on Jul 13, 2008
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
SOURCE: how do I remove links from geneva wrist watch band
Take a small hammer and a plastic push pin. Look at the pins in your watch. One side will have a line going through the tip of the pin, and the other side may also have that, but it will be less pronounced. Set your watch on a soft surface (couch cushion or cork board, for example) and place the pushpin onto the pin you want to remove. Tap with a hammer until a few millimeters are sticking out on the other side. Take a pair of needlenose pliers and remove the pin. To put a pin back in the band, push it back in until you cannot push anymore, then use your needlenose pliers to push the pin in the rest of the way. Good luck!
Posted on Feb 07, 2011
How do I remove a link in the steel wrist band on my watch
no details or photos so the best advice is to take it to a watch shop or jeweler and have it done
Dec 15, 2015 | Watches
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
Apr 27, 2014 | Citizen Eco-Drive BL006056H Wrist Watch
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    How do i shorten a metal watch band i have a casio 708
    Look for removable pins in the band to allow removing one link at a time until it fits ok.
    Dec 06, 2009 | Invicta Pro Diver 9321 Wrist Watch
    Wrist band adjustment
    In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
    I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
    It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
    Jul 01, 2008 | Casio G-Shock G7000D-8V Wrist Watch
    Tessot steel wrist watch band
    Jan 13, 2008 | Watches
    Fossil AM 3688 Wrist Watch Logo
    1,059 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    john h
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
