Question about Dwin TransVision 3 Plus Multimedia Projector
No video is coming out of my Trans3 projector what can it be?
    Problem Solver:
  • 6 Answers
Not sure. I am looking for parts for mine. Please help if you can. Will buy dead projector. dgrayid@yahoo.com
Posted on Dec 10, 2009
My laptop is coming through purple through my projector
Mine does this often. While everything is still set up, projector on and signal coming from the laptop, I just unplug the video feed to the projector and plug it back in. This usually corrects it.
Sep 14, 2010 | Sharp XR-10X Multimedia Projector
Projector will come on but lamp will go out
still too warm. it need to cool down more. could also be a ballast issue. if the caps are drying out, a boost of power could overload it and it'll shut down.
Aug 06, 2009 | Nview Z215 10.4" LCD Panel with Video(16.7...
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Dwin Trans3 Plus will not lite
I had a similar problem and it turned out to just need a good clean. The fans can pull in a lot of dust and eventually this causes intermittant starting problems/noise. I attacked mine with compressed air and a vacuum cleaner and this completely fixed the problem. Try to control where the dust goes you want to avoid just blasting it inside the unit and on the lense, bulb, etc
Dec 31, 2008 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Eiki LCSB Projector: no input
make sure the resolution matches the input.
Sep 14, 2008 | Eiki LC-SB20 Projector Multimedia...
S-Video, want to hook up my laptop, won't play
those weird names are types of video, you want that on auto...you need to set your display to detect another monitor or lower your resolution settings as well as your refresh settings (hertz) on your laptop
Nov 09, 2007 | Philips ProScreen 4600 Impact Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
126 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
