Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Wireless not working, went into setup and enabled
Netopia router wireless not working, was working fine last night, went into setup and enabled the wireless, still not working, still shows not enabled, powered down, reset etc. router does work but not wireless
  • acetum
    acetum May 11, 2010
    Do you have any wireless filtering turned on? I would reset the Router to factory settings then work from there.
    Sergeant:
    Champion:
  • 310 Answers
1. Please make sure its the router and not the laptop. can you get the laptop to scan for other networks . this is to make sure that the issue is with the router and not the laptop. 2. goto the setup again and try changing channels to 11 or 4.
Thanks
Ranjit
Posted on Oct 06, 2009
Router was fine last night - but the two wireless computers in the house are unable to get online this morning. What lights are supposed to be "lit" on the front? I see Power wlan and Internet are lit now.
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Open the router page (192.168.1.1)
2.Enter the username and password (by defualt password is admin and leave the username blank)
3.In the router setup page click Wireless and fill the sections and mentioned
Wireless Network Mode-Mixed
Wireless Network Name- As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Now click Wireless Security and select the Security mode as WEP
5.WEP Encryption should be 64 bits
6.In the Key1 enter a 10digit/10 letter password and click save settings.
7.Click Advanced Wireless Settings and fill the section as mention
Beacon Interval-75
Fragmentation Threshold-2306
RTS Fragmentation-2307 and click save settings.
8.Turn off the router for 30 seconds and then turn it on and try to connect your laptops.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys Wireless-G WRT54G Router
Power went out and now my router is working fine but the wireless PCs cannot connect. "Limited or no connectivity" even though signal strength is excellent. Tried cycling the router. no luck.
Access the router's setup page/configuration page and change the channel of your wirelessrouter to 1, 3 or 11. Make sure you know if the wireless encryption is ON and get the key.
May 12, 2010 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Netopia 3347 wg not giving wireless signal. its ok when connected directly. was working ok last week. Q6
This is a problem with the routers firmware so to correct this better do a firmware upgrade with this unit and you can get the firmware from the manufacturer....
Sep 15, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How to get nat 1 netopia router 3347 ps3
  • you need to access the router access page of the router, look at the bottom for router access page or call router support
  • then go to WAN setup to enable/disable NAT
Aug 11, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Jun 10, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Netopia 2247nwg router
Well I'm no expert on routers, but I've never heard of Netopia. If you can, try Linksys routers, they're so easy to use and they have the best customer service. I have a Linksys WRT-54GL Wireless Router linked up to a Wireless-G PCI adapter. I wont lie to you, Linksys is very easy to use, and you can see any activity on your network straight from your computer. I got my setup for less than $50.00, but I don't know if they got cheaper or not. They're blazing fast too, they can transfer data up to 54Mbps or higher, I've never used anything quite as simple as a Linksys router, I did have and old Aris router, but it was too difficult to use, so that's when I bought the Linksys. You won't be disappointed!
Hope this helps some!
Oct 05, 2008 | Netopia 2247NWG-VGx Wireless Router...
Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Aug 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
No wireless
first make sure wireless enabled and find out what channel the item your trying to connect to is the same as the router and set both accordingly. I had same problems with security cameras i turned security settings off for wireless and switched everything to channel 6 on router and cam and wet with 806 and works fine had to restart router not reset.
Aug 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
423 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
