Question about Emprex LM2201 22" LCD Monitor
EVERY TIME THE LM2201 MONITOR IS PLUGGED INTO THE ELECTRICAL SOCKET, IT MAKES A HUMMING NOISE?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Ruth_coleman, Only a guess but I would say that the "switch-mode-power-supply" or "backlight inverter power supply" has a problem. Is screen always BLACK? how old is unit? How many "ON" hours on this unit? Is unit new? Out of warranty? Did it ever display a PERFECT IMAGE on it? When? Did it always HUMM?? FYI check out VIDEO clips of LCD monitor disassembly and repair on YOUTUBE to find out what is inside a typical LCD display. You will have a better handle on what to do about getting it repaired or to trade in for new. Yes, monitors can be REFURBISHED with new SMPS/Inverter boards for $50-$100. Check out some ADs here on fixya. I'm louie12fix on fixya or lmistyrel@aol.com please rate this response and get back to me if you need further assistance. Bye for now.
Posted on Oct 05, 2009
Car surging at idle, and making humming noise.
I can relate my experience with a similar noise on my 1994 car with Traction control. A electric valve in the air intake made a "Hum" or "Buzzing" noise when malfunctioning. For my car, the valve was suppose to reduce engine RPM so the wheel spin was stopped by choking off the air to the engine.
So the electric valve on your engine may be getting a bad signal from the Traction control system especially since you are not applying power. Or simply the electric contacts in the part you mention are worn out and "buzzing" because the contact points are burned out and can not connect.
Jul 05, 2013 | 2003 Ford Explorer
Onkyo system HT-S7300 overheating shutting off humming noise
check the electricity plug > check the electricity cable of the reciver < and the best thing put every three electronic device in on plug not more and the best thing go to the company to check your reciver
Aug 23, 2012 | Onkyo Audio Players & Recorders
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Why is it making a humming noise
If it is humming ONLY when you connect it for charging and does not hum when you have no load on it...it has too much initial load and the humming is caused by an output current overload.
I don't know what you are trying to charge....if you are VERY careful and you can monitor the output current load....you may be able to get a charge....BUT BE VERY CAREFUL!
Mar 09, 2010 | Schumacher & Fast Charge Starter Charger
My laptop froze one time and i had to hold the power button to shut it down. when i turned my laptop back on which is plugged with the emprex, the emprex LCD monitor went to auto adjustment by itself and...
try to do a syestem restore on it. click on start go to programs. then accessories system tools and at last system restore. and go back to the last time it worked ok.
good to you sawdust46
Jul 31, 2009 | Emprex LM2201 22" LCD Monitor
Syncmaster710N
There are no speakers attached but if for any reason humming is comming its the transformer inside the casing. Very comming in transformers that after some time they start humming noise.Its not for all of them but its some coiling fault but it doesn't effect anything.
Jul 24, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Humming noise
Make shure your wall socket is grounded.Pull cover and look for black and wite and green wires on the back of the plug.Also may have leaking capacitors in final output stage may need a repair man look at the directory on this site.
Nov 17, 2007 | Pyramid XPA200 Amplifier
Emprex LM2201 22" LCD Monitor Logo
67 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
