Question about Samsung DLP HL-P5663W 56" TV
Problem on Samsung 55" set can't remove base
Can't remove base from bottom of set
    President:
  • 1,653 Answers
A difficult one as Samsung do not recommend that this uint is wall mounted but there should be 4 screws attaching the stand to the base of the TV chasssi but if you do remove it you will end up with a gap in the cover as Samsung do not provide blanking covers to cover it up.
Posted on Oct 05, 2009
Cannot removed the subtitle at the bottom of my 55 inches HD Samsung tv. Remote control is a Samsung AA59=00601A
You probably are seeing closed captioning (CC). This usually is enabled/disabled as part of initial set up.
Jan 26, 2017 | Samsung Televison & Video
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
The bottom stand
Is that the 'neck' part between the flat base and the TV? You should have disconnected the neck part from the back of the TV... Instructions are in the operators manual.
Apr 07, 2010 | Samsung LE22A457 22 in. LCD TV
Static on Plantronics CS-55
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Jun 25, 2009 | Plantronics PL-CS55 Wireless Headset
Samsung 4235X/XAA older Plasma TV Need to take the base out for m
GENTILITY lay that set face down on a table covered with a thick blanket. There should be 4 long threaded bolts near the bottom that fasten the legs of the stand inside the framework of the set.. Remove these and the stand should slide right out.
www.mcveyelectronics.com
Apr 11, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Wall mounting tv. How do I get the base Off?
Are you wanting to sell the base? My base is broken and I am trying to buy one.
Jan 03, 2009 | Samsung LN-S4051D 40 in. LCD Television
LCD TV Set up
no tips, but if you have tip on how to remove base that would help us out..we hung on wall and cannot remove the 4 screws to remove base, only 2 would come out.
Jan 01, 2008 | Samsung LN-R409D 40 in. LCD Television
Phone
You may need to set the handset in the base for 30 seconds. Press the page/find button on the base, if you have one on your model.
You should also verify that you have power to your base. Make sure that it is the base, and not an extra charger, if you have more than one phone!
Jan 01, 2008 | Lands Phones
Samsung DLP HL-P5663W 56" TV Logo
197 people viewed this question
Henry  Thomas
Henry Thomas
